Rear Inner Fender Liner Removal
EddieC
Any hardship removing and reinstalling rear inner fender liner on 2008 Tahoe?
I see a number of small hex head screws and a few push pins.
Anything hidden?
Just asking before I jump in.
It should be just as you see it. Easy Peasy. The push pins often get damaged upon removal, so you may want to purchase a few extra ones before you start the job.
EddieC
EddieC
Thanks. Did it today and, as you said, nothing to it. The only hardship was the phillips head screws for the mud flaps. Because the screws had rust on the threads the phillips grip was not sufficient to coax the screws out and I had to cut the heads off with a Dremmel.
Luckily I had a bag of GM equivalent push pins on hand that I got from Clips and Fasteners.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yup, once you realize how easy they are to remove, front and back, you don't mind removing them during future repairs/inspections. :)
EddieC
EddieC
Well, maybe just a little in the front.
scottd
