Blown Headgasket?
Woldy1
Hey y’all, So in my ‘04 Yukon I am noticing that I am losing a small amount of coolant while driving. It holds pressure well so it’s not a leak but I see that it holds some pressure even 10+ hours after driving. I am hoping that it could be something small like a bad Coolant reservoir? Other than that it runs good and doesn’t overheat.
Marky Dissod
I am losing a small amount of coolant while driving. It holds pressure well so it’s not a leak ...
One or the other - can't be both. Mutually exclusive. It ain't Schroedinger's cat.
If you have a garage or a regular parking spot, put a very large piece of cardboard on the ground.
The wet spot will point toward where the problem is, but you'll still have detective work to do.
Other thing you can do is apply 15-20 psi of active pressure to the cooling system while the engine is cold, and look for the leak that way. RMI-25 or any other additive that contains dye will make the leak more obvious.
There's a decent chance that some part of the rear auxiliary cooling system could be the culprit.
Look for wet spots in the back ...
cjmcglaughlin
Gettysburg, Pennsylvania
If you can’t find an external leak, it could be a head issue, the Castech ones are known for this. The head crack allows coolant into the oil. Could also hopefully be something else like a head gasket, or even an evaporative leak from the radiator or reservoir cap. I’d say try to check your oil for any coolant. Also look at the head casting number (it’s on the front corner of the passenger side head, right under oil fill tube). 706s made by Castech are known to crack. Only way to know for sure it your head is Castech is to pull the rocker arm, as their logo would be underneath. Wish you all the best.
W
Woldy1
I’m pretty sure it’s the headgasket, I checked oil many times after driving long distances and it looks normal, The reservoir hasn’t ever been replaced.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What is the amount your are losing over what time period?
I was loosing a pint a every few weeks. No leaks on the ground or hoses. Eventually I saw the radiator support was wet under the left radiator tank. It was weeping, but not enough to puddle on the ground. I replaced it and it's been holding rock solid level.
drdave81
Waterford, MI
Do you get white smoke on start up? Does your exhaust smell sweet? That would tell you if you're getting coolant into the cylinders. It could still be a head gasket, or even the head, depending on where the head cracked. What casting number do you have, 706?
If you decide to do some testing, buy or rent the tester that will look for combustion gasses in the coolant. Here's one from NAPA, but every decent auto parts store will have one to rent or buy.
Mudsport96
40.923,-89.488. Illinois
It could be a myriad of things not necessarily a head gasket. Your best bet it to add a dye and pressure test. There is NOTHING worse than cracking open an engine to fix a nonexistent problem. I learned that lesson young, when I pulled a head for a head gasket that was fine. It ended up being a bad vacuum modulator on the transmission feeding atf up to the passenger side of the intake manifold. So a 20 dollar 10 minute fix turned into 100 dollars and a day and a half.
W
Woldy1
Unless the reservoir itself is causing the leak I’m not sure it would need to be replaced. Like others said, any white smoke or sweet smell?
No smoke, besides vapors cause of cold weather, I’ve had this issue since July 2023. After some more testing I think it might be the radiator.
W
Woldy1
Yea I’m pretty sure I have the 706, exhaust smells normal I think it’s just time to replace the coolant lines and radiator
W
Woldy1
I was loosing a pint an every few weeks. No leaks on the ground or hoses. Eventually I saw the radiator support was wet under the left radiator tank. It was weeping, but not enough to puddle on the ground. I replaced it and it's been holding rock solid level.
About a pint every 1-2 weeks
cjmcglaughlin
Have you looked all around the lines/rad for any weeping? Also if you haven’t changed the oil since this started I’d recommend it, just to look for sure if there’s any coolant in it. Sometimes it can’t be seen on the dipstick.
That's too slow of a loss to visibly show in your oil. I wouldn't rule out a cracked head or failed head gasket. These types of leaks tend to only happen when it's warmed up and when driving, so they often pass the pressure check. It only takes about an hour to pop off the valve covers to inspect for the common Castech failure.
W
Woldy1
Oil
was changed not too long ago, Didn’t see anything abnormal. I don’t see any leaks on the ground
W
Woldy1
Check the weep holes on the water pump too. If you get a radiator, make sure it has the proper orifice in the tank return tube. Otherwise, the truck will never properly get to temp.
Will do
W
Woldy1
I will check that, Thank you
W
Woldy1
Thanks for all the help y’all, I’m pretty sure I found the issue, I testing everything and it’s not a blown head gasket, I found a nice wet spot under the heater core lines and plastic fittings on the firewall, so I’ll get that replaced and let you guys know how it goes.
BadDaddy2003
