What did you do to your 21+ T1XX today?
Runfor5
Northern VA
This could very well be spam on Craiglist given the awkward text and 1 photo lol, I just saw it, but if not then wow putting 95k miles on one in <3 years sure is something.
Geotrash
Dave
Richmond, VA
Yeah, and I'll bet the title is in "escrow" until they can get cash from you to send to the escrow company to release it.
Jimbo123
Threw the Corsa on before I left work on Friday. The sound is absolute perfection.
I'm toying with the idea of removing the Corsa and going back to stock. Every time I go to leave in the AM and one of my kids is still sleeping, I wake them up :doh2:
Maybe I should put it up for sale, considering I have both head pipes so it can fit a standard Yukon AND Yukon XL. Someone make me an offer that's near the Chicagoland area!
Vladimir2306
In addition to standard wheels, custom design wheels were ordered. In black. Forged, rated for 1200kg. Standard wheels for 1000 kg. Weight is less than 15 kg, standard ones are about 20-22 kg. These wheels will be used for the summer))) On a car this is a computer fitting))
CMoore711
There's a lot of great benefits to forged wheels compared to cast; Definitely offer a weight savings especially when considering rotating mass.
Will you have the option of running them without the center cap that covers the lug nuts like in the first picture? AND with the optional center cap that does cover the lug nuts like in the last picture? Or did you have to choose one or the other?
Vladimir2306
When ordering, select either a disk with a cover or without a cover with open nuts. At first I chose one with open nuts, but then I changed my mind and asked to change the layout to a disk with a lid. This is the so-called Dynamic cover; it does not rotate during movement. Here's a video of what it looks like on an Escalade rim)))
GTPace500
dont do it. It's too much damn fun. I smile every single time i start the truck.
Here's mine: https://www.tahoeyukonforum.com/thr...-6-2-rear-alignment-issue.140511/post-1800867
JayceeP
Approved the factory order for my Pearl Beige Yukon XL SLT!
Jimbo123
Well, I think I've made up my mind after waking my kids up again both days this weekend. Let's get this Corsa exhaust to another forum member - $1000 OBO!
Vladimir2306
Easier said than done at 5:30am on weekends when I head out to run.
It seems to me that in such conditions it was best to make a controlled exhaust. You press the button and you get a roar and a roar, press it again and you get a standard quiet exhaust
tagexpcom
Just added Autostop to my 2021 Yukon Denali 6.2L - https://www.autostopeliminator.com/collections/gm/products/2021-gmc-yukon-yukon-xl - AE029 harness. Very professional, first rate unit, plugged in like it was OEM.
In my case, I pulled the bottom panel and side panel as in youtube BUT... I don't have a small panel above the AC vent. The screw was on the side toward the driver's door. Removed the screw and then the panel with autostop button pulled out - it has plugs that keep it in place. Easy access after that.
Took me 10-15mins and I was being slow - And it works!
j_jerry79
