Shudder at 20mph on deceleration.
Writefast
So this is my next repair. I have a subtle but distinct shudder on decel. It’s most noticeable at 20 mph, may start being noticeable earlier at around 25 but it really ramps from 23-22 down to 20. It gets increasingly less noticeable down to about 13 mph then it’s imperceptible if it’s there. Happens with brakes and coasting. I don’t feel it in the steering. Don’t feel it in the pedal. I just “feel” it. SOTP maybe? It’s less noticeable when I manual it to 3rd and decel but it’s still there. Haven’t been able to test 2nd or first yet. The way it comes on and dissipates fees like a sympathetic vibration. Motor mounts? Never had a mount fail so no clue what that feels like. Ideas?
Dustin Jackson
Bad motor mounts would certainly make whatever is happening more noticeable. One way to check motor mounts is to gun the throttle really good from a stop and if you notice a thud or clunk that is probably your motor twisting under the hood because the motor mount has work and the engine is able to move around. Another way you can check is pop the hood and put the Yukon in drive, hold down the brake while you give it a good amount of throttle and you should be able to see the motor jump around if the mount is bad.
Another thing to check is is AFM is engaging or disengaging causing shuttering, you can to this by monitoring the V8 and V4 indicators on the MPG display.
Lastly, if the plugs and wires haven't been done in a while a weak spark would cause similar symptoms but I think the problem would be more pronounced over 45mph when the TC has locked up.
Marky Dissod
V4mode should not be available in 3rd 2nd or 1st - but check anyway.
Next time you are decelerating from 30MpH, move the shifter into neutral.
If the shudder is not there in neutral, change your ATF and ATF filter with Dex6.
@NickTransmissions
NickTransmissions
Sin City
The transmission bench
Let's start with what year, engine and transmission your Tahoe or Yukon has, how long this has been happening, what (if any) significant service work was done recently (what was done, when) - provide those details and we can respond based on that new info...
mountie
I had a similar 'shudder' from my 700r4 ( '88 GMC truck)...... It was a bad lock up in the ( torque converter ) Maybe , Nick Transmissions will chime in ??
I don't have any knowledge of the differences of converters from then, and newer.
NickTransmissions
Sin City
His signature says 07 and he said he puts it into “3” so guessing 4l60e
Thanks, Dustin - sig doesnt show up when holding my phone vertically and wasnt exactly sure how to interpret "manual it into "3", lol...
Id agree, converter is likely going bad...He can confirm with a bi directional scam tool with trans and tc data streams displayed while driving. Any converter slip speed outside of reference ranges would verify a bad TCC...
Writefast
Writefast
How much for one of these? (Never mind that but. Got a cost range. Still would love suggestions for brand.) And do you have a brand suggestion?
Writefast
Writefast
Update. Took her to the transmission shop. Nothing wrong. He took it for a drive and when he got back said “good news there is nothing wrong with that transmission. But, man, that is weird.” He suggested maybe a sticky u joint so I’ll be looking at that next.
Yederick
Any resolution to this issue? I have the same problem on the deceleration from 25-15mph!
I've had my 08' LTZ [2WD 5.3L 4L60E w/ 220K on body, 50K"ish" on Jasper engine, 24" wheels] for <2 months: tires have less than 5K miles and apparently the 24s have been on it since 2012; I had them rotated and balanced to cure a wiggle in the steering wheel at around 50-55mph; new radiator installed 2 weeks ago; still addressing some electrical/ground issues as well as the dreaded evap debacle..
I'm still wrenching through her character flaws, of which there are many, but she's a solid TN truck, still looks great and well worth all the pains..
Took her on the first (mini)road trip [2.5 hours away] to see a concert with my daughter a week ago, and the problem seems more pronounced since.
I haven't tried to move it into neutral to see if it stops the vibration yet, so that'll happen on my next drive. I did notice the other day that there is a noise in conjunction with it; I had the driver's window down while crossing a short bridge and the sound bounced off the abutment. Hard to explain, but I'd liken it to a stick in a fan blade.. and the noise follows the velocity. Next repair will be U-joints, but I'm not 100% certain that's gonna solve it.. I read elsewhere in the forums that a similar issue turned out to be a rear carrier, but hopefully mine doesn't come to that.
scottd
