I Sank my 2003 Z71 Tahoe
matsmiley
matsmiley
Can anyone please help with the amount of diff, transfer and trans case fluid amounts I should put back into the truck?
Also I think a ground may have came loose because when cranking everything sounds fine and will fire up with starting fluid but not idle. No bad sound coming from engine and no metal in the oil.
Thanks again for everyone’s help!
Also, the only reason it wasn’t staying on idle was bc of water still being in the gas tank. So I completely dropped it instead of just using a siphon.
Jumpshot12
