yep, then your seats are warmed up too lol
Roger that.It sounds like everyone is having the issue when embarking immediately following a cold start. You could remote start it 5-10min before leaving and let the engine warm up before driving. If the noise persists, that could help eliminate possible causes.
Thanks for the update. Keep us posted. I’ll update once the dealer gives me the full rundown. I saw earlier where some said rear diff is covered under certified pre owned. Hoping that’s the case.Engine warm up makes no difference (at least on my Tahoe). The noise occurs until the differential is warmed up, and the engine does not warm up the differential. It needs to be driven to warm up the differential.
I changed the fluid in mine today. I'll update with whether it made a difference after I put some miles on it.
I'm pretty sure everyone of ya'lls trucks have remote start that could prevent this. That being said, if 6 members are having that same issue in this recent of a thread, it may be a widespread issue that's TSB worthy. Definitely make your dealers aware of the issue.
Can you share the TSB? The dealer that examined my Tahoe claimed they were not aware of one.There is a TSB.
It took a little bit of driving but the noise has gone away with the fluid change. For reference, mine started making noise around the 45k mile mark, which is when they recommend fluid changes in the tranny and differential.
What type of gear oil did u use and how much? I can’t find any info on it
My 2wd 2021 suburban is doing it when warm also. The loudness varies though. Is it the electric power steering unit?must be a T2 thing, I have had front differentials for 25+ years (multiple GM vehicles) and only had 1 make noise when 4wd was "engaged" and moving any direction, regardless of temperature.
there is a TSB on the front diff's making noise for thr 2021+ I guess the fix is a fluid change of some formMy 2wd 2021 suburban is doing it when warm also. The loudness varies though. Is it the electric power steering unit?
I thought that was for g the rear diff (mechanical locking version)there is a TSB on the front diff's making noise for thr 2021+ I guess the fix is a fluid change of some form
