Need help with 2010 Hybrid Escalade
makintoshnex
makintoshnex
Interesting. Now I have fuel pump ⛽
makintoshnex
makintoshnex
and it's still missing? ugh.
it looks like you got it nice and clean.
does it still sound the same as in that video?
Truck running with 14.2 volts. That's still missing I will do that 7 cylinder tomorrow. It's really dark and cold+ rain
makintoshnex
makintoshnex
It's missing on idle. But not much. And it sounds normal not huf puff.
j91z28d1
it's even to cold down here in the south to be outside working on stuff. I don't blame you.
I was thinking it was with the truck off, but wanting to make sure. since there's a big 150amp fuse the charging system runs thru.
has the miss code for a individual cylinder shown up yet since the new wires, or just the p0300 one that isn't specific.
all those other codes not really related to the miss are a mystery to me. wish I knew if it was really all related or just coincidence
j91z28d1
there's another guy currently dealing with a randomly stalling out problem, not the same as you have. but it lead him to the fuse box. I guess you can pop the fuse box like in half top to bottom, and check for corrosion inside. he found it wasn't fully seated. with all the weird codes you are getting, and low voltage I thought of yours while reading thru.
Post in thread 'Is there any certified GM techs in the group? U0109 is driving me insane.' https://www.tahoeyukonforum.com/thr...0109-is-driving-me-insane.144686/post-1840522
just a thought. I've never had one apart thou.
makintoshnex
makintoshnex
Ok, I will take a look. I'm waiting for my delivery from Amazon, I ordered some brake switches and it's control module. I have a guess. That's might be the abs module itself. It's all corrosion on module. Maybe there is bad connection.
makintoshnex
makintoshnex
For me the biggest concern is that Stabilitrack. Because I can't move vehicle.
I can't do to highway, and can't drive more than 20 mph. I don't know how Stabilitrack is related to spark plugs and coils.
j91z28d1
it won't let you drive faster than 20mph? I've not had mine give me issues, I didn't expect that. I thought it just disabled it. if you need to drive you can try holding the button for 5 or 10 seconds to turn it all off. it's the one down below the radio with the little car on it.
you might check, I believe that abs module, if it's the one I'm thinking of needs to be programed to the truck. your scanner might do it. I don't know anything about the one you have but it seems to show stuff byond just the engine ecm, so it's probably better than normal cheap ones. if doesn't the dealer can do it. worth a search thou.
makintoshnex
makintoshnex
I mean I can't drive faster, just because it is not safe. I bought some parts. Let's see what I can do. Maybe some switches are bad.
j91z28d1
ahh we don't get ice and snow down here, so I never considered it being used for actual stability lol. most of my cars either don't have it, or like the c6 it gets turned off every time I get in it.
good luck. Hopefully something helps.
makintoshnex
makintoshnex
Okay so what I've done. I removed the fuse panel top of it. Put it back together again .Connected the battery terminals and just started right away. I got 15.6 volts in the system. After a minute or two it dropped two 14.2 volts, engine is idling like new. Literally like new. Nothing really wrong with it. This truck is a mystery for me. I still having that stability track day. I cannot program the ABS unit. I cannot do anything. I need tech to win I think. I bought one long time ago but it was a Chinese knockoff and it was not working at all. So far I don't have a boost. My brake pedal is really soft. I don't want to mess with it. I noticed that board itself. It's not original. It's a delphi. Some blocks are Delphi as well. Also, I noticed a lot of corrosion on the ABS control unit work at the picture.
j91z28d1
looks like you've definitely found something worth cleaning in that fuse box. I've never had mine apart, did you just flip the 2 levers and pull? I should probably check mine too even thou I don't get the corrosion you get.
yeah, I'm not good on the programming modules, I believe that sounds right thou. there's a 100 page thread around here somewhere. it sounds hard to get the China one to work. I believe it only works with a old windows xp laptop. but the non China is very expensive. might be better to just pay a dealer to flash it. I wouldn't expect them to charge more than an hour labor?
there's some kinda brake pressure calibration these trucks need, I messed around with a scanner once when I first got mine and dumped all the pressure out of the booster and it felt like crap, long peddle and no stopping power, I belt it was throwing a code of some sort too, but I don't remember exactly. it might be what yours feels like? like old manual brakes in a 50s farm truck lol. I used the scanner to run the automatic brake bleeder function, but I didn't actually open the bleeders and make a mess, just did what it said on the screen. it runs thru a bunch of tests and makes you pump the brake pedal a few times, and when it was done, it worked again. since you need power assist even when the engine isn't running these have an accumulator and pumps up to like 2500psi or something like that.. so when you hit the peddle, that's your assist. it also needs to know the peddle travel amount for the regen battery charging and all that stuff too.
the braking system on these trucks is way over my head. I read about it and just hope it doesn't fail haha
glad you're making progress thou
makintoshnex
makintoshnex
Well I would not call it a progress. More and more I lean to only one thing defective ABS module. I really have a big trouble replacing that brake light switch on brake pedal. It's not looking like regular GM trucks. Mine is so stiff that I can't do a thing.also I would replace brake pedal position sensor. If that is not going to help I would take that fuse box apart. And if that not going to work well 2 ways either look for used ABS module or junk the truck.
j91z28d1
oh, I thought it was running better after messing with the fuse box.
I got nothing for changing the sensors and switches. anything under the dash is always a nightmare for me.
makintoshnex
makintoshnex
You know what I never looked at??? Freaking speed monitor sensors. They cause that Stabilitrack too. I just remembered when I was changing rear shocks I had to disconnect them. So I forgot to put them back, and upon starting I noticed Stabilitrack notice. So I had to jack it up again and plug it back. Now in order to get up to the coils #5 and #7 I had to get somehow into engine bay . I had to put my leg inside of a wheel and step on a spoke. Maybe I screwed up cable from speed sensor. Because for now I did pretty much everything what I could. It should give some results. I got rims like on a picture
j91z28d1
anything is possible. worth looking forsure.
I was hoping when you cleaned the fuse box the voltage would get higher to everything that was throwing all the random codes and they would go away.
maybe just clear everything out with the scanner, do the trick where you take the battery cables off, hold them together for a few mins to drain any power keeping memory alive and then hook up, run a full scan and look at live data to see if that braking module has good voltage close to the battery voltage at the time.
if your scanner is high end enough you can pull up the sensor voltage from each of those shock ride sensors to see if they are giving useful data.
makintoshnex
makintoshnex
I will try to bring it to the shop next week. It requires lift. I can't see from my point anything. I think you might be right. Dealership may reprogram module, I think they would try to sell me one but not fixing existing. There also might be a problem with fuel pump. If there is bad connection it would give same code for Stabilitrack
makintoshnex
makintoshnex
That's m8x25, coil bolt holder. Now I need to get 16 of them. Truck is at the shop, no news for now
j91z28d1
fingers crossed you get good news from the shop
Conedaddy
