hmclaughlin67
My vehicle is a 2005 Yukon XL SLT. I went to remove my spare tire as the rim is beyond rusted and the tire doesn’t hold air anymore. The cable comes down ok, but the spare stays up. I read in the owners manual about a second latch mechanism, and I tried to follow it but it seemingly made no change. The wheel can be moved freely, so it didn’t rust to the vehicle itself or anything. It also appears to be the factory spare based on how severe the rust is to the wheel. Anyone ever had a similar issue and any idea on how to fix it and get this spare down? I have a long trip this weekend and was trying to put on the replacement spare I got.
B-train
Yes, the second safety latch is most likely rusted solid and will never come free. Support the tire, get a grinder and cust the cable/spring off to drop the ride. Throw out the rusted spare and buy a new one. Also buy a new tire support and lube the shit out of it before reinstalling the next tire and wheel.
H
hmclaughlin67
The tire doesn’t even drop low enough to access any portion of the cable that’s supporting the wheel. Any other ideas? I was going to try to see if i could manage to squeeze a can of WD40 in there to maybe lube things up just enough.
B-train
Cut the end off that holds the cup and spring. The wheel will drop down. Then take down the junk mount with a 13mm socket and throw it in the garbage
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Check out @Tonyrodz post here too:
Super common issue. You must live in the rust belt.
S33k3r
Dallas, Texas
See if you have a place near you like this:
Dallas Makerspace
Then get it up on a lift to check it out.
Alternately, you could be an ass like me: I took our Suburban to Firestone under the assumption I still had the factory spare; the factor spare from 2004, and it was now 2019... I bought 5 tires from them, and asked them to change the spare out for one of the new tires... Worst case scenario THEY break it. For me, they got it down, swapped out, and my spare carrier still works...
H
hmclaughlin67
Dallas Makerspace
I ended up jacking up the spare tire like it says in the owners manual to release the secondary latch, except i just held up the tire and not the latch and let it hang. Then I used a flathead to pry the latch off myself and dropped the jack until the tire came loose and fell to the ground. All in all took about 10 minutes and was super simple. I thought about replacing the whole hoist system, but decided to just stick a flathead with the spare tire removal kit and call it a day. Thanks for your help everyone!
SilverSport
does anyone just remove the spare and leave it off???...it sounds like so many of us have this issue partially because they've never had to use the spare or is the spare part of the "rear end crash system" where it provides some protection for occupants in a rear end crash?
Bill
Bill
I don't carry a spare, as I had to remove it to install my Gibson Extreme cat back dual exhaust system. Instead, I carry this with me for a potential flat tire.
S33k3r
Dallas, Texas
I don't live in the rust belt but we do have corrosive de-icers applied to roads in the wintertime. I exercise my spare at least once a year by dropping it -- usually when I rotate tires -- and lubing the mechanism as needed. Use it or lose it, is my thinking.
Do you only rotate your tires once per year? This is one of the few pieces of information I did not learn from my dad...
justinakay79
