Rust on fenders?
jonnyjonnyjonny
Hey guys I wanted to buy this 96 Yukon and it looks to have rust on the quarter panels (?) on both sides. The seller says it is only surface rust. Is there an easy fix for this?
If I do go to buy it, what should I look for in terms of rust?
(Disclaimer: The owner did say that there was no rust underneath)
LordWayback
There is no easy fix only bandaids for “easy” , if it’s truly surface level a palm sander and duplicolor perfect match do gods work
LordWayback
The frame crossmembers front damper upper mounts , swaybar mounts and leaf spring shackle mounts check the upper rails above the doors and rear glass sometimes water gets trapped and eats it from the inside out same with the bottom of the doors check fuel tank straps everything else is case by case also these things in 96 have spider injectors my friend has a 97 we just put a MPFI conversion on it was a pain in the butt
LordWayback
Is it that they tend to go bad?
It’s a matter of when they go bad that truck started as a weird detonation noise and misfire and turned into replaced spider injectors and more they got “stuck partially open” and were dumping fuel into the intake and causing the detonation issues
LordWayback
Also, attached engine bay photo
Has spider injection system don’t know if it’s ever been done but it tends to start failing at 140k-200k from what I’ve heard the factory system receives fuel pressure and uses it to mechanically fire the injectors if you have low enough fuel pressure the injectors will not fire even if they are working
wjburken
Eastern Iowa
Where is the truck located? Is it where they like to use road salt?
Looks pretty clean, especially for a ‘86, but I live in Iowa where they apply salt rather liberally in the winter.
If I were looking at it, I’d look closely along the chrome trim on the fender arches for any sign of bubbling paint. I’d look inside the wheel wells along with underneath along the rocker panels.
J
jonnyjonnyjonny
Hey! It's located in Canada, over near Vancouver. Looks pretty clean for a Canadian vehicle, I will make sure to keep my eye out, it's a 96 with 291,000km on it.
B-train
Agree with @wjburken If it's not rusty underneath, the door seams look good, etc then you probably have a clean truck.
The rust does appear to be surface related from years of driving with no mud flaps. Sand it down, prime it with rust converting primer, and coats with matched paint, or use black bed coating for a thicker, tougher repair. Then put mud flaps on it.
Hoesgottaeat2
Western NY
Another '96 owner here. Mine's brutally beat up by salt in our region. Just about to hit 204k miles. Engine runs strong. No known issues with the fuel injection system in the nearly 20 years I or a former owner have owned it. Former owner is a close friend of mine and I did his repairs for him when he owned it.
The body on that '96 you're looking at appears to be decent from the pics.
Be prepared to replace things like brake lines, fuel lines, etc if it has surface rust.
I'd also look at the body mounts to verify integrity.
But at first glance you likely have a solid candidate to purchase IMO.
YukonGTmaster
2 Door w/ Barn Doors Club
Hi, I am from the Vancouver area. I had bad rust on my '97, but that is mostly because I took it to the land of salt and gravel in Alberta. If it has spent it's life on the B.C West Coast, it may only be surface rust. I would sandblast the area, apply Corroseal, smooth, prime, and paint. Or just run it and enjoy, if it does not bother you.
strutaeng
Dallas, Texas
You can open the throttle body blade and try inspecting with a small mirror or borescope to see if the injectors were upgraded.
The upgraded MPFI have 2 wires running along with fuel hose. The actual injector is on the tip instead of it in the "spider body." See previous post by @LordWayback for photos.
Spider injectors/fpr going bad will give lean, rich or both codes, depending on what fails. Also will give misfires and crank-no-fire conditions if fpr or injector leaks down when you shut off the engine and floods the cylinder.
LordWayback
Or it lights the intake on fire I have seen one burn down
LordWayback
Continuing on the spider injection thing if you have a fuel pressure test gauge hook straight to the fuel rail schrader valve and there’s a PSI range if memory serves you need 53 psi at the rail to fire the injectors so leaking fuel lines (rust zones) failing fuel pump or filter/ bad pump harness among other things may mis-diag a spider injector
wjburken
Eastern Iowa
Had a 1997 with spider injectors with absolutely no issues after 200K miles.
waveryd
IL
I had a '96 Suburban that I drove daily for 20 years and 600, 000 miles. I never had any fuel injection issues at all. A friend owns the truck now and it still runs just fine. I never gave that truck a chance to fail, it was on the road every day. They are good vehicles. Simple to work on and parts are cheap.
pwerwgn
Open all doors and check behind the rubber seals at the bottom.
j_jerry79
