Tahoe front wheel well SPATS
EdTom
I recently ordered a 2024 Tahoe RST, production has been pushed back twice already. Scheduled now for first week in January. I’ve taken notice that some of the 2023 models come through with rubber front wheel well flaps that extend down (in front) of the tires. Can someone answer what that ridiculous looking item does? And more importantly can it be removed easily? Thanks
n4gkj
Lexington,Ky
i have no real idea what they are for.. assume they are for aerodynamics...
Yes they look stupid....
i took the whole panel off the bottom and used a box cutter to trim off the "flap".
i think there were 6 or 8 6mm body screws....
i put the panel back on...
i thought about leaving it off but i was afraid air would get behind and blow out the flimsy wheel well liner.
Stbentoak
I could be wrong, but sometimes things like this have to do with cooling airflow and air ducting. They have to have SOME purpose....
E
EdTom
Thank you for the information. I noticed there is an option for upper and lower Aero airflow which supposedly aids in cooling the engine and aerodynamics? Not sure if those flaps are part of that. A lot of new ones don’t have the flaps so it could be tied to that option but I’m guessing. At any rate, your high country looks great without them. I’ll be doing the same thing if mine arrives with them.
66 Galaxie
The rebate for aerodynamics and do not come with the Z71 package
Sparksalot
Bastrop County, Texas
What are you trying to show here? I see a bumper.
StephenPT
St. Helens, OR
He's showing what it looks like without the FWD "mudflap."
As @Stbentoak mentioned - they have a purpose. Either aerodynamics, engine cooling or both. There's a handful of features on the vehicle done in an effort to eek out every little bit of aerodynamics possible on a 3 ton rig... You can see in the same picture the opening in the grill at the outboard edge that channels air into the wheel well. Also at the back of the rear wheel well is stamped feature that tunes the air flow. They wouldn't add these features if they didn't have a true benefit.
E
EdTom
I’m sure there’s validity in everything you stated. I’m personally not sure the perceived benefit is worth making a classic great looking vehicle look ridiculous with that silly add-on design
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
My initial hunch was some kind of spray deflector when hitting a deep puddle.
E
EdTom
I believe they are called “chaps” and their purpose is aerodynamics
Thanks for sharing that. I’d love to see the engineering stats on the aerodynamic benefits of those. Hard to believe they’re even worth the effort.
Sparksalot
I’m guessing y’all are talking about something like this…
The minute aero advantage, is wildly offset by tire choice. Meh. Some tape as a guide, and 5 minutes with a cutoff wheel will fix that.
E
EdTom
Don’t think we’re talking about the same thing. We are discussing the rubber flap or chap extending 8” (in front of the front tires) out of the wheel well. They’re being installed from the factory on late model Tahoes and I guess Suburbans
Sparksalot
That’s why I asked in the first place…
WalleyeMikeIII
Sunny and Snowy Minnesota
Several articles about them online, and several styles. But I used the wrong term….spats is correct so study up on that.
Big Jim
