justchecking
Military
SW Ohio
On the road again. Appears I have increased my gas mileage 20-25% while towing the camper. Normally I just leave it in Tow/Haul where it usually stays in M5 and rarely M4. I saw a post from @NickTransmissions to use M4 and M3. It always seemed like it was lugging in M5 pulling my 5000LB square camper. I manually put it in M4 now and M3 up hills. Fuel mileage went from 8+ to 10+ (depends on weather etc). More testing needed however.
RooTBeeRthe1st
So today we forgot to get gas and then made a wrong turn. Display switched from 35 mile remaining to "Fuel Level Low". Drove around 20 more miles before getting gas and the needle was about 1/16" below E. Took 27.5 gallons to fill up and supposedly 31.5 gallon tank. So about 4 gallons remaining. I wonder how much of that is useable before we are on the side of the rode?
Ah, you have the long wheelbase, my tank is only 26 sadly.
But according to my incorrect reading fuel sender that I just pulled out, you can get pretty darn far.
When I went to change it out, I was in the driveway which is a slight incline, and cycled the fuel pump to get the last 4 gallons out, and there was only around 1 quart left if that.
Literally a splash before it started pulling air.
The way they're set up, the plastic canister the fuel pump and filter and sending you net sit in, literally rest on the bottom of the tank. They're pushed down by the springs on the rods attached to the top of the tank.
So it'll draw every bit out that it can.
alpha_omega
Michigan
Well…no work on the Denali this week. The wife decided that she wanted to get the first buck of the season.
I think she could have gone about doing so using a much cheaper alternative. Body shop quoted $15k for repairs (parts & labor). Thank god for insurance.
However, my pup is happy with his new chew toys.
And momma is excited about driving the rental vehicle I picked up for her. Just what she needs…another red sports car to drive while the deer are in rut.
Maybe next week I get my Denali pulled into my shop so I can work on a little prior to it going in for the trans rebuild.
alpha_omega
Michigan
Drove it across a creek, up a hill and into a cow pasture at our friends’ farm so the kids could meet some cows.
Nice green scenery. I had to double take for a minute and make sure you weren’t parked down by my pond taking photos. Your friends pastures are not quite as high as my hills are, but it looks almost as steep as the grade on my property is. Let me tell you…mowing those 15-20° slopes often gives you quite the pucker factor. Using cows is a much safer method than the one I’m using.
alpha_omega
Michigan
Gruvin power folding mirror rebuild kit on the passenger side yesterday due to a failed gear.
I put it back together with some areo grease/slide glide.
Luckily i bought the kit for both sides!!
So today, i installed the driver side.
Went much quicker once i had done it before.
Is Gruvin the company who’s owner is does most of the work in house with a skeleton crew of guys. He will send you parts to DIY, or you can send him your mirrors for 2x the cost? They use metal gears instead of plastic? Am I thinking about the right company?
Just Fishing
Can't fix stupid
Utah
Sounds right.
I did the diy, good solid instructions on the site and youtube.
The youtube vid didn't go very far into detail about a mod they suggest you make to one of the metal parts that you don't replace.
Hardest part was getting the housings separated, and then making sure you get it together correctly if you don't pay special attention to the direction of the arrow when you dissemble... lol
But yes, they do offer it as a service, diy, or a core return deal.
Just Fishing
Can't fix stupid
Utah
Gruvin also sells those metal heater core t's.
Where the pastic ones are known to get brittle with age and burst.
I actually lost the heater hose end this summer.
Cooked my brand new engine a bit.
My AFR bar code on my passenger side head has a little yellowing from the heat now...
3k heads nearly destroyed due to a fkn plastic part...
Thanks GM!!
alpha_omega
Michigan
I put the filter in mine many moons ago, but I still get this very dirty smell switching between AC and vent.
Need to clean the evaporator one of these days.
Pick up one of these - eBay item # 144208517264
Make sure to have some sort of drip pan under the filter area when you spray the aerosol cleaner up on those fins.
Just Fishing
Can't fix stupid
Utah
Did you replace it with the metal one from Gruvin?
nah i got a set of OEM T's for it when I had the engine and transmission out.
I also have a heatercore bypass valve that's getting installed before next summer.
I plan to bypass the heater core during the summer.
the bypass: https://www.amazon.com/dp/B0989DJLXJ
Seems like a great idea.
RooTBeeRthe1st
Purchased! Thanks for the tip!
justchecking
Military
SW Ohio
Sounds right.
SO I was going to do that this summer in the warmer months, but the kitchen remodel intervened. Should this be done when the plastic is WARM or would later this month when temps are in the 40s be safe(for the plastic)?
Just Fishing
Can't fix stupid
Utah
What I had fail was the one and only heater core hose+connector that I didn't replace while the engine was out.
It looked like new, so i figured it had probably been replaced before.
Before it happened I kept smelling dex cool.
right before we went up the canyon I was sniffing around after picking up the inlaws.
No puddles, just a smell.
I wrote it off since the week before that my wife's car blew a water pump and lost coolant all over the driveway.
figuring I must have just run through it and picked up the smell + my nose is sensitive to shit.
I assume during the winter it's better.
I always seem to have issues on the hottest day of the summer.
Like loosing the water pump on the wifes buick, and then the tahoe losing the only line I didn't replace!! :banghead:
On that note, the Jeep had some questionable heater core lines.
one of those "gee I should replace those while the engine is out" then a "oh fk that I can't find them online?!".
Right after that happened I just disconnected the heater core lines and installed a loop to the two ends on the water pump.
Now it's getting cold, so a very near future me task to complete. :rolleyes:
Just Fishing
Can't fix stupid
Utah
Don't forget that the heater core provides a little bit of engine cooling in the summer. It's dissipating heat while the engine coolant is circulating through the core.
Seems like right into the dash and back area?
with my luck it will pop right as I'm headed up that fkn canyon with a boat in haul.
(that happened to my S10 one year)
Also strange, I lost the heater core in my S10 in the exact same place as the tahoe lost it's heater core lines!
:whymewhyme:
Geotrash
Dave
Richmond, VA
:whymewhyme:
Must be hard 0n cooling system components - like the Eisenhower Tunnel climb in Colorado. When I lived in Colorado I used to see people broke down on the side of the road every time I made that drive.
Just Fishing
Can't fix stupid
Utah
I moved the tahoe, made the mirrors flip in and out a few times.
So much faster now!
before it was a short wait, now it's almost switch blade fast. :ehcapt:
I also think my neighbor might have backed into the front of the tahoe when I had it parked in front of the boat last week.
the camera showed them getting really close, and right after I cleaned up the headlight assy.
Now I have the grill poking out just a little under the chevy badge, and the headlight is loose on the bottom.
it didn't show a solid hit, so whatever.
if something like a tab is broken, then I have a fancy little plastic welder.
So far it has been great.
I have used it for a few projects now.
Only complaint, it overheats too quickly and won't work until it cools down.
I extended the use time by dissasembling and drilling a bunch of holes in the case.
Last use was about a week or two ago.
I fixed the fenders on the Jeep, installed staples and melted in some filler.
I found I could use an air hose to flow some air through it, and that would get it working much faster than waiting for it to cool off.
Great little tool, soon I need to fix the crack in my dash.
went out to the junkyard yesterday to get a part for the 05 and saw there was a couple fresh gmt900's in the yard so I grabbed a spare heater blower motor for the yukon
the 07-09 blowers are a different design than the 10+. they will both fit but the older ones use a internal air vent to cool the motor and the newer design uses a vent off of the airbox with a small funnel.
brake pedal pads are a different size also 07-09 are smaller and 10+ are bigger.
and found a spare rear view camera and figured out how they are removed and so I grabbed it as a spare in case mine ever dies
I have read on here before that people say you basically have to rip the trim piece off to get to it but that is not true, there are screws and it all comes apart
can't get this p0420 code to go away so ordered 4 new 02 sensors as a gamble just to see $177.00
if that doesn't fix it I will try and get the cat warranted but doubtfull, stupid thing is only 6 months old, the 02 sensors are about 5 years old with 75k on them.
something seems to be borderline the code will come up after 3-4 days right before it should be ready
JamesinAbilene
