Issue starting 2015 Yukon after changing transmission wire harness
Mongolas
So I have a 2015 Yukon XL Denali with the 8 speed transmission. I just finished installing the wire harness with the temp sensor, thankfully it was the two piece wire harness so I didn't have to take out the valve body. I'm pretty sure I got the connections all in the right spot. Got the oil pan reinstalled and bolted in, then added about 9 quarts of fluid until it leaked out. Was going to pull the plug after it was running for a minute and circulate through the system so it can be at the proper levels. But when I went to start it, at first the noticeable symbol was a car and lock symbol. I figured maybe it didn't like it being on the jackstands, so I took it off of them and tried to start it again, still the same issue. After several attempts, the car and lock symbol doesn't show up anymore, but it still won't start. I have had the battery disconnected for about 20-25 minutes to see if that will reset anything, but I'm at a loss. Thankfully I'm off for two more nights, but I work third shift so it's difficult to work on cars at night. Any help or advice would be very appreciated, as I cannot find much of anything online in terms of trouble shooting.
NickTransmissions
Sin City
The transmission bench
Do all of your accessory and vehicle external lights work? Radio work?
If so, sounds like the IMS isnt communicating with the PCM. If no comms are being received from channel N (or PCM doesnt recognize the IMS input signal) then vehicle wont start because the PCM cant confirm the trans is in Park or Neutral.
M
Mongolas
Thank you for your response. Yes, the dash cluster, headlights, internal overhead lights, as well as the screen in the center seem to work fine. Everything appears to be normal except the engine starting. Radio even kicked on after disconnecting the battery for a bit and reconnecting it. I really want to make sure it's something I did before I drop the pan again and check my connections, but I'm 99% certain I make sure everything was connected as it should be, and made sure the connections were secure. If it's a communication issue, what are my options?? I'm pretty low on funds at the moment until payday.
M
Mongolas
Also, I noticed in one video that someone made doing the same repair that they connected all the wire harness connections without cleaning it, so I followed his example. I hoped that the fluid isnt xonductive but that is currently my main concern and the reason im 99% sure I did it right and not 100% sure.
NickTransmissions
Sin City
Depends on the cause...if you did everything correctly, your next step is to pull the IMS connector and begin ohming the pin sets to check for damage and see if each change from open to closed while someone else runs the shifter through the gears. If channel N doesnt respond then the IMS is bad and needs to be replaced. This ATRA webinar handout should help get you started...skip to page 41 for the Internal Mode Switch.
This is one possible cause so up to you how you want to prioritize it against testing for other causes..
Also quote my posts so I know you responded if you want me to reply back...otherwise i wont know you have replied.
M
Mongolas
So it would seem that I dont have much choice but to open it back up again and check the connections? Will I need to clean any fluid off of the connection before connecting them?
NickTransmissions
Sin City
Do what you can to rule everything else out first before taking the pan off but if you're unable to do so, that's your next step. I always use CRC QD Electric cleaner on connectors but not sure it's mandatory - just my personal preference to ensure there won't be any problems...
M
Mongolas
Okay that sounds good. I have a mechanic just down the road from me that I talked to earlier. He said if he has time later this afternoon, he'll come down and scan my issue. But he also doesn't think the fluid being in contact with the connector is an issue, which was something I wondered, so my mind is more at ease, and hopefully maybe it's just a matter of resetting something. This whole debacle has definitely made me start shopping for a good scanner to diagnose my own check engine lights.
NickTransmissions
Sin City
I'd absolutely get a good bi-directional scan tool...These days, you really can't be without one if you want to do any diag/troubleshooting yourself...
Look into Snap On or Autel...Autel scanners are a little less expensive for much of the same capabilities you would want to have though I think they're made in China while the SnapOns are made either here or in an allied country...
The other consideration is whether you want a stand alone bi-directional scanner or something that has both bi-directional scan as well as lab scope capabilities...A third consideration is whether you want something with WiFi...The more features you have the higher the price...
Also make sure you buy something that is still supported and upgradable by the manufacturer...Since your vehicle is fairly recent, new information and/or module updates may be developed and pushed out to end users for updating...Snap On's website has all the scan tools they currently support (I imagine Autel's does as well)...Other makers include Bosch, OTC/SPX and Innova but I don't know anything about them...
M
Mongolas
That's a lot of good information, I appreciate it.
My mechanic was nice enough to come down and use his scanner (his shop is just down the road from me) and it threw a bunch of codes indicating one of the main connectors was not connected. Not sure how it wasn't since the thing can only be connected and locked or not connected and very loose since I tried to play with it when I had the pan off a second time. I wiped some of the excess fluid off and reconnected it, making sure it was locked and snapped in. Got it all put back together with the fluid re-added and it started right up. No more check engine lights and it seemed to of fixed my main issue, with easier shifting. It still sometimes shifts SORT of hard, like noticeable, but it's not HARD hard, if that makes sense. And the temp sensor works, it just takes a little bit of driving to get up to temperature. But all in all, it seems to be okay for now.
I was looking at Autel scanners on Amazon but kind of figured they're made in China. I'm willing to drop 1000 dollars on one eventually as I really don't want to have to rely on others to address any future issues. The thing I hate the most about working on cars is just not knowing what's wrong, and figuring out what it is. Physically replacing parts is a lot easier than figuring out what the problem is to begin with. I'll check out SnapOns though as I'd rather pay a little more for something that I would assume would be better.
Conedaddy
