Buying 2011 PoPo Package Tomorrow
Hey everyone, was on Jeep forums for awhile til my Junk Chrysler motor dropped a valve seat, unibody rot, blah blah blah.
I test drove a 2011 RWD police package tahoe last week, scanned it- didnt throw any codes.
130K miles
Guy wanted 5500 I talked him down to 5
The Good- He swapped in leather seats 2nd and 3rd row, K n N intake, bodys pretty clean, no frame/undercarraige rust really at all. Motor runs great needs an oil change, tranny shifts like a brand new tranny-steering felt good, brakes, etc. Motor sounded mint- no lifter tick or oil leaks I noticed.
The Bad- I need to put tires on it (got some mint ones from my jeep >100 miles on em P255/75/r17) Theyll fit without rub hopefully, right? noticed oil pressure at 1/4 on the gauge, looked at oil its time. Needs shocks. Needs front blower fan.
Before I take this thing to get an NYS inspection to make sure it passes,
What are some other things to look for on this truck before buying it? Been awhile since I have dealt with GM vehicles.
I would assume that the PP Tahoe does not have AFM
It does have AFM Ron.
Welcome to the forum popo! These things have an idle oil pressure from the high teens to about 30 psi.
Those tires will work, the speedometer will be off though. The stock police tires are wider and shorter. The tires on a regular Tahoe with 17s are P265-70R17
Hoesgottaeat2
Western NY
Did someone say police? In NY? Oh boy...
Greetings and welcome from NY!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
130K miles
Welcome!! Check into if the AFM is still in use or has been removed or tuned out. If there is a Range device plugged into the OBD port you will have to unplug that for a week of driving to reset the readiness monitors for emissions inspection.
You PPV/SSV guys, if his vehicle does not have a DIC switch is he still able to toggle the display somehow to show V4/V8 mode on a test drive?
Sparksalot
Bastrop County, Texas
I could not see V4/V8 until i added the DIC. I could most definitely feel it though. Driving through my old neighborhood, mostly flat, in Drive doing 25-30, and it would go into V4.
Welcome to the Forum from NH.
Pics of the truck, please.
While not needed for inspection, be sure to change out ALL of the cooling hoses sooner than later, as they will fail in time and dump out out coolant in less than a minute.
PopoPackage2011
Aw shucks guys thanks. I dont think it has an AFM nothing was plugged into OBD port. This this is an ABSOLUTE ANIMAL on the highway. Just pulled it into my garage, oil change time for halloween
Couple things I noticed- It probably (hopefully only this) needs a front fan blower. Nothing really comes out but on highway some hot air seeps out the vents. Rear blows hard. The back passenger windows dont work, but the motors make noise. My passenger rear blinker does not blink- thought it would be a bulb......it runs off the brake light bulb. Any ideas?
Thank you in advance. Will post pics tomorrow after wash. Happy Halloween!!!!
justinakay79
