blueinkd
- Joined
- Nov 21, 2017
- Posts
- 646
- Reaction score
- 1,558
Also,
PSA: after you finish for the day...and all the sheet metal is ready and fitted. Make sure you move it before you move your truck!
I had to use the drive side piece and redo it... the bends were too much to straighten...
Finally, I installed the C-bar LED tail lights.Wanted to change the look of the rear tail lights, so last week I bought the C bar leds. The new ones came in today, if I have time tomorrow I'm going to install them.
Might sell the old rear leds tail lights.
They look good.Finally, I installed the C-bar LED tail lights.
Man rockers are no joke, so much time and effort.I cut out my passenger rocker and replaced it with fresh metal. I cleaned all the loose rust off, used Corroseal on the inner rocker and used POR-15 inside the cab corner.
I welded the new panel in place. Ground down the welds and used a little Bondo to smooth out the transition from the fresh metal and the factory rocker (profile is slightly different).
I then masked the cab corners, fenders and inside the cab. I primed and followed up with bed liner.
I plan to install Trail Armor plastic rocker covers, once I finish the driver's side.
PSA: Don't put Corroseal on anything you are planning to weld ..it takes forever to grind off... super tough.
I just cut off the driver's side today and will put the new one on this weekend....Man rockers are no joke, so much time and effort.
I still have small holes to patch up on my passenger side that I have been putting off for months.
Is that the Alta station, or somewhere else? Boy, do I miss my corn gas!Put in a half tank of corn, actually E70, to top it off. This station is super-consistent with the ethanol percentage, it's even marked at 70% on the pump. Can't beat the price and performance!
I replaced my sparkplug wires, a while ago, and while I was there, I cleaned the valve covers.. I can't figure out how the valve covers got so dirty... It's not as if I had a 327 Chevy with a leaky carb and lots of blow-by.....Is that the Alta station, or somewhere else? Boy, do I miss my corn gas!
On another note, I finally decided to pickup a 5.3 from an ‘04 Burb… I really wanted a 6.0, but they’re getting harder to come by, and spendy.. got this one for $500, and was a good engine when pulled, so hopefully in decent shape. I’m planning to bore it over a bit for some extra cubes.. so far, it’s not too bad as far as bolts / corrosion. There were 2 broken exhaust manifold bolts, but the rest came out fine. Heads were definitely dirty.. not too good about the oil changes apparently..
What're your plans @Sam Harris?Is that the Alta station, or somewhere else? Boy, do I miss my corn gas!
Nice! That’s the fuel I was using before finding the Alta, which seemed to have a better ethanol content than the K-U-M & go. Glad it’s working out for you. Hope they keep the E85 around.I haven't been back to the Alta station in a long time, at least not since the K-U-M & Go station opened at Arapahoe Rd & Peoria Street. It's right on my way to the office when I go, and the E85 is consistently E70, so super convenient.
I'm not sure if they'll continue to carry E85 (hope so) since Maverik convenience bought K-U-M & Go. Have to see when they rebrand.
Well, my bottom end in the Yukon is pretty worn. When I did the head and cam work, the cylinders had very little cross hatching left in them. (I mean, it does have 235k on it..) so I’m hoping to get a few more cubes out of this block, and build it up a bit, since I’m currently consuming more oil than I’d like. Outside of that, not sure.. I’d like to build it stout, for some forced induction, but will have to see how things look as well. Cost is obviously a factor. So for now, I want to freshen it up, but will see what it looks like, and what I can afford to put into it. Ideally, I’d like more cubes, and a nice turbo setup.What're your plans @Sam Harris?
Nice. If you put a 6.0 crank will that make it a stroker motor?Well, my bottom end in the Yukon is pretty worn. When I did the head and cam work, the cylinders had very little cross hatching left in them. (I mean, it does have 235k on it..) so I’m hoping to get a few more cubes out of this block, and build it up a bit, since I’m currently consuming more oil than I’d like. Outside of that, not sure.. I’d like to build it stout, for some forced induction, but will have to see how things look as well. Cost is obviously a factor. So for now, I want to freshen it up, but will see what it looks like, and what I can afford to put into it. Ideally, I’d like more cubes, and a nice turbo setup.
ProCharger?? IMOWell, my bottom end in the Yukon is pretty worn. When I did the head and cam work, the cylinders had very little cross hatching left in them. (I mean, it does have 235k on it..) so I’m hoping to get a few more cubes out of this block, and build it up a bit, since I’m currently consuming more oil than I’d like. Outside of that, not sure.. I’d like to build it stout, for some forced induction, but will have to see how things look as well. Cost is obviously a factor. So for now, I want to freshen it up, but will see what it looks like, and what I can afford to put into it. Ideally, I’d like more cubes, and a nice turbo setup.
I believe that would work but, I have no idea.. lol. I have research to do… if I could just do a longer stroke (assuming the bores are good), that would be ideal. Just need to keep a close eye on tolerances.Nice. If you put a 6.0 crank will that make it a stroker motor?
