Mirror conversion
Douglas Friedberg
USA
2006 Yukon from factory no heated mirrors. But power mirror. Stand size not towing and not power collapsing.
Need to replace someone wacked it off. Can I upgrade the mirror to heated mirror ?? Drivers button console has no provision for heated mirror ie the center button. However I tried changing the push button assy awhile back and bought the button console driver side with the heated mirror option and the new one would drain the battery over night even though it was non heated mirrors. So I had to reinstall old unit and return new unit. So it seems that nothing can be a plug in without reprogramming system.
Anybody firmillyar with this kind of swap????
Douglas.
I thought the mirrors heated when you used rear window defrost.maybe that’s the newer ones.
That's how I understand this also. I have an 03 Tahoe LS that only came with heated and power mirrors. I added the mirrors with the turn signals and powerfold. Everything was plung and play, no bcm programming needed.
Douglas.
03-06 you can upgrade to power fold, turn signal, heated by changing the mirrors and the drivers door switch for them.
auto-dim requires the auto dim rear view mirror because that is where the sensor is (additional wiring may be needed also, not sure).
00-02 you can add turn signal mirrors but the turn signal function will require running a wire from the bcm to both mirrors
I have not seen any power mirrors that were not also heated, they work when the rear defrost is activated as already noted above
Douglas Friedberg
Douglas Friedberg
USA
Thank you and I see the lodgic in this as well. Being your knowledge here do you know why a major battery draw would occur when the wrong drivers door panel window switch assembly is installed just because vehicle doesn’t have heated mirrors installed and happens while vehicle is not running ??? Just curious ?
Thanks Douglas.
johnsonwillie199
