Center console question
J
Jbirdstruck
ATX
So I ordered a used console got the trim pieces, rear cubby, drink holder, but when I go to install the black box on the floor prevents the console from moving forward far enough (about one inch)!! Has anyone else had this problem or know of a fix other than cutting out a notch in the bottom of the console so it fits?
Baddawg
Vail, Colorado
I'm interested in this topic, wish I had a console.
What is the black box that gets in the way? Is that something that is only on the PPV / SSV models?
Thanks!
CrashTestDummy
Pearland, Texas
Thanks!
That is the roll-over sensor. It'll tell you when you're on your roof. :anitoof:
I had to trim some of the bottom plastic away from the base of our console so it would fit around the sensor properly. It depends on the vintage of the console, though.
Also, feel around under the mat near that sensor. You may find a harness. IIRC, there have been others on this list noting they found a harness that just plugged into their replacement console that at least let them get power to the in-console USB socket. Worth a try, but I wouldn't expect much.
Sparksalot
Bastrop County, Texas
The old hoe didn’t have one, so I made one. I made the U in utility rather large.
signguy62
NJ
I just ran into this. Installed a center console from an 07-13 Suburban into my 07-14 Tahoe. Just used a sawzall and cut a notch in the black ABS base. Fits perfect.
signguy62
NJ
I'd really like to find one of these. They seem to be like a Unicorn.
Shackman7878
San Bernardino
I'd really like to find one of these. They seem to be like a Unicorn.View attachment 406385
From what research it was more common on baseline Silverado, on mine I bought a Abs plastic sheet and cut it to fit then used small square of plastic on the sides to hold it.
Examples:
signguy62
NJ
The storage bin or the little mat?
Both. I bought a junk yard console and there is nothing in that spot. Don't need the rear controls. So looking for the cubby instead.
Ilikemtb999
Denver
I bought some ABS 1/4” sheet and acetone welded it together to form a box. You couldn’t tell it wasn’t factory. I don’t have pics because I’ve since sold that Tahoe
It was probably $10 total and you can buy everything at any hardware store.
signguy62
NJ
Yeah, if it wasn't you then someone else also suggested this.
Thanks!
Shackman7878
San Bernardino
Thanks!
how it looked version 1, If I get more time I might try and 3d Print something
Deennoek
