6.2L or Duramax reliability
Geotrash
Dave
Richmond, VA
As a species, we're going to have to figure out a way to take CO2 *out* of the atmosphere eventually, and store the carbon as a solid or inject it into disposal wells, or both. It's the only way I see to avoid the problem of governments continuing to increase restrictions on what people do.
WalleyeMikeIII
Sunny and Snowy Minnesota
We have a way to do that…
Grow plants…Trees, corn, grass, flowers…magic…
C02 + sunlight + water = plant material + O2
The key is, after it starts growing, don’t burn it down (see deforestation)
WalleyeMikeIII
The future of the global climate will be decided in Asia and Latin America, by poor people who couldn’t give a-s-s about saving the planet. Good speech about it, bang on.
Konstantin Kisin
Exactly. You could take US emissions to almost zero and it only makes a small dent in the problem.
jmzvet
San Diego
I went over 5K miles before mine said the DEF was getting low. It still had about 25% remaining. 2.5 gallon container is about $12
homesick
The Best Me I Can Be
Navy Air Force
Isn't CO2 plant and tree food?
Governments are magnets for the greedy, the crooked, and the sociopaths. You will never get governments to stop trying to run your life. The protections our founders built in are steadily being destroyed.
Dumb and dependent is the perfect citizen.
joe
dbphillips
You don't say you are going to tow, but if you are, get air suspension . There is no identified solution for squat on the premium suspension models.
It's kind of criminal the tow package doesn't include some kind of static air leveling, given they have all the parts.
Geotrash
Dave
Richmond, VA
Of course, but as we lose flora through deforestation and our rate of fossil fuel use continues to grow, more carbon dioxide is introduced to the atmosphere than all of the plants can remove. It’s going to take some mechanical/chemical assistance, I believe. Fossil fuels remain too important to human life to stop the use of. So from a pragmatic standpoint, an engineering solution is needed.
TollKeeper
Brighton, CO
And of course, and engineer will make it WAY harder than it needs to be. Just look at some of the engineering they do for what should be simple repairs on cars.
Ex: On my Pontiac Aztek, they want you to drop the engine cradle a couple inches to replace an alternator. Backyard ingenuity found a simpler solution thou.
rswaug
If you go with the 6.2, just run premium gas and stay regular on oil changes. Most of the issues you’ll hear about stem from the owners not doing one or both. Most of the issues were also relegated or a run of late 21s and early 22s as well.
Ovrhdbryan
I’m having a hard time deciding if a Diesel is right for me, but a local dealer has a great one on the lot and it’s tempting. I only drive about 12 miles round trip to work and don’t really get over 45mph as its down the beach. Am I going to have issues with the diesel potentially not gettting up to temp on a regular basis? I can take the long way every so often, but that seems like an unnecessary inconvenience.
altona
Parrish FL
12 miles is plenty to get the diesel up to temp. I routinely drive 5 miles most mornings with no problems in 18000 miles.
luvHarleys
The babymax really doesn’t need the love old diesels may have needed l, although my diesels just required good maintenance - it’s just attention to require maintenance that should be done
Change the oi and filter @ 5k or 7.5k, and you’re solid - personally I chose 5k intervals. And, I’m planning on doing the fuel filter at 20k mI, we’ll in advance of schedule.
The babymax is a solid superior engine. It’s sneaky fast and a bit torquey - have to love how it just does what you want to do, even towing more than you every thought with a 1/2 ton.
GMT800 2005 Tahoe Z71
Navy Supporting Member
It has likely been said before, but I am old and forgot. With the Duramax engine, is it an Allison transmission?
StephenPT
St. Helens, OR
Nope - the Allison is only with the 6.6L Duramax in the HD trucks.
The 1/2 ton platform uses the GM 10L80 transmission behind the 3.0 Duramax.
HeavyHoe03
