2005 Z71 Tahoe hot air
Jasonrebellion
I’ve owned it for about 2.5 years, had no issues with the AC, would freeze you out. I bought a new daily driver and I let it sit long enough to completely kill the battery to where it wouldn’t hold a charge. I replaced it with another yellow top Optima and it immediately started blowing the hottest air I’ve ever felt. Doesn’t matter what I set the temp on, just pure unadulterated heat out of both sides. I feel like it’s unlikely it just randomly sprung a leak from sitting for 2 months but I don’t know where to start and funds are limited. I have checked all the fuses. Thanks for any help. I did search before posting but may have missed something.
mountie
I just had my alternator replaced. Before it was replaced, at the repair shop, the A/C was perfect. Vents were cold. When I started the 2005 Yukon at the shop, with the new alternator, the vents were HOT.
I shut of the truck and restarted it ...... The vents went back to cold again, and perfect since.
( I think the vent actuators just needed some encouragement when I restarted. ? )
Do you have the rear A/C ? If so, is it hot?
J
Jasonrebellion
The rear ac has always been stuck on ac, but now it’s just blowing ambient air. The air out the front is pure heat though
ivin74
05 NBS Nali
Htown, Texas
Do you know if the HVAC system has refrigerant?
ScottyBoy
Shreveport, La
My truck sat for almost a year while I waited on a new engine. After I FINALLY got a new crate engine installed, my AC was blowing HOT. Sure enough, I had no refrigerant. My Schrader valves had a small leak, and it sat long enough to leak out.
So check all the easy stuff first, make SURE that it still has refrigerant, then go from there.
willinnashville
Nashville
Similar thing happened to me last week in my 2005 Denali. I disconnected the battery for a valve cover replacement. After I was finished I fired up and had hot air on the passenger side but cold air from the driver side. I did the recalibration steps basically the same as the video below and it's been fine ever since.
048tahoe
