travo87
- Joined
- Jul 1, 2023
- Posts
- 46
- Reaction score
- 26
So there is a couple questions I have but first here's the issue that I am having. When I try to start it it only shows like 10 10.5 volts on the charge indicator gage on the dash but battery reads 12.13 volts and when I go to start it all the dash lights radio just cut out and off and then there isn't nothing(as I'm trying to start the truck) but sometimes the horn goes off like an alarm but my horn don't work when you push it. Sometimes I'll get lucky and it'll turn over but my main issue is that I need to replace the flex plate cause my starter chewed up the old one. I've replaced the coil ignition coil pickup ignition control module plugs wires rotor and cap now the starter battery and started bolts I've looked for a short or grounded wire under the dash and by the under hood box and I've replaced the fuel pump relay no blown fuses or anything so I'm at the point I just ens t to blow it up but I cant I need this truck it's my money maker
