Rough idle/ shuddering in idle.
j91z28d1
you don't remove the broken manifold bolts to install the clamp. it's that ground that makes it hard. you can't hardly get wrench on it except a swivel head ratchet wrench and at an angle. the bolt tq is almost 40 lbs at the factory before 20 years of corrosion.
there's just no leverage. it's the only hard part of the install the rest is just fiddly. I had to stick a pry bar thru the open end of the ***** and against something I don't remember and pull till I thought I was going to break the wrench.
solli5pack
Would it help to remove the coils and valve cover? I'm about to do one on my Yukon tomorrow. Also it seems the Dorman bolt fits into the manifold hole so how does it push down on the manifold?
j91z28d1
it probably would help to pull the valve cover. I didn't thou. let us know what you use to break that bolt loose.
all the broken off bolts I've see don't sick out of the manifold, so it OK to press on the hole. if you mean in lines up and goes into the hole that's not right, it should just hit the manifold itself.
I didn't get the Dorman one, I just got a random Amazon one, but if you can tell form the pic, there's a flange nut on the end of the bolt that pushes against the manifold. if yours happens to line up perfectly and into the hole, you might need to add a not or something on it.
If I was doing this I'd also add a jam nut on the bolt above the bracket.
solli5pack
I got the Dorman 917-107 and it didn't come with the flange nut. It came with three bolts. Two for the back of the head and one that threads thru the bracket and it looks like it would thread right into the head. I'm going to get a flange bolt to put on so it will push down on the manifold. My head bolt is broke and recessed into the head. If I wasn't so weary from my Suburban AFM delete I would pull the head and do it right.
j91z28d1
I think you'll be fine.. these seem to work well. I've checked mine a few times and no leak I can find. I'm definitely not pulling a head unless I really really need to. I'd probably try 3 different ways of getting it out before resorting to a head haha.
GMT800 2005 Tahoe Z71
Navy Supporting Member
When I did mine, I cringed because the only quick thing available was Dorman. I installed them and they have been fine for 2 years now.
donjetman
I didn't
Here is what I did use/do w/pics almost 5 yrs and 60k ago and still going strong at 190k:
https://www.tahoeyukonforum.com/thr...-cold-berryman-b12.120184/page-2#post-1469315
and
https://www.tahoeyukonforum.com/threads/exhaust-manifold-bolts-no-bueno.108605/page-3#post-1296439
solli5pack
I hate Dorman for even inventing this thing!!! LOL!!! I got the old bolt off and bracket is on with the top bolt in. Trying to get the lower bolt on now. I took valve cover off, jacked up the trans and removed the heat shield..You definitely need patience and some beers with this job...
When I did mine, had a lift. Definitely way easier.
solli5pack
I gave up for the night. Couldn't get the bottom back bolt to thread in. Give it another shot tomorrow...
Get a mirror and a light in there and make sure is all lined up for the bolt. Then, hold your tongue just right and say effin this and effin that a couple times and remember, righty tighty, lefty loosey. Are you able to loosen rest of bolts to allow play to help get that bolt in?
j91z28d1
if it's not going in its probably the hole not drilled right. I'd open one up bigger and try.
you can also test fit it on the driver's front side to see
solli5pack
You mean the hole on the bracket? I used a mirror and it seems pretty well lined up. I'm thinking of getting a different bolt with a tapered end. Hoping that would thread in better.
solli5pack
Yeah it seems lined up. Multiple F bombs dropped and bruised face from falling wrenches..try again today after work.
j91z28d1
I'd double check just to make sure.. doesn't take much to not wanna start right.
I'd check on the other head or run the next size drill bit thru both holes. won't hurt anything and make it eaiser.
solli5pack
So I tapered the tip of one of the bolts that came with the kit and got it in first shot. Everything else went pretty smoothly. Definitely need patience putting this thing on. Even removing and reinstalling the heat sheild is a struggle. It's a doable project though. Unfortunately this didn't cure my at idle misfire on cyl 5. At least now I know the sound I thought could possibly be the exhaust leak is probably lifters rattling in the tray. So the heads going to end up coming off anyway...lol. I know the manifold was leaking though so when I get a chance I'll do the shop vac thing and see if it sealed the leak.
j91z28d1
glad you got it.. sounds like a hassle. I didn't even see how to take the heat shield off. I can definitely see that not being fun.
shame it was something else.
Conedaddy
