Gas mileage
Cartier16
Chevy sucks.
13mpg average at a half tank drove 15mi commute. Steady drive entire time with some stop and go traffic driving like a grandpa to keep Instant meter averaged 16-25mpg the entire drive. Started with 136mi to empty ended at 87mi to empty in a 15mi trip. Absolutely terrible almost 4 gallons of gas in a 15 mile drive with about 4 miles of highway included. truck has a brand new fuel pump and fuel filter in it. I would nail my mopar to the floor every chance I could and still get double the mileage.
Miami-Dade
Moderator Supporting Member
Chevy sucks.
Next time you post please put down year and model you have. You posted in 2021+section. Went threw your old posts to find what to drive.
Click bait titles do not help to get answers.
Cartier16
Cartier16
My bad I put it in general discussion. 2003 GMC YUKON DENALI 6.0 AWD 180,000 MILES New fuel pump fuel filter spark plugs cv axels radiator after market air intake. Since it’s all so relevant and contributing to cheap gm crap
GMT800 2005 Tahoe Z71
Navy Supporting Member
The info center is not the perfect gauge on what mileage you get. Any stop and go driving lowers mpg, that is a fact. Do you really think 4 gallons of gas was used? Time to do some actual research. Fill with fuel, drive and fill again and compute the mpg the old fashioned way. @Miami-Dade is right, click bait titles tend to turn some people off and they skim right on by to the next thread title. Why was the fuel pump and filter replaced? Aftermarket air intake could be contributing to the problem. Did the manufacturer guarantee better mileage? Plus, it always helps to not complain and name call, TILL some details are shared and response come back. I help less when someone has their mind made up to the negative.
Devlin
I live in the mountains and have an 06 Denali XL. The avg MPG gauge is a joke. It only registers when you are pressing the gas pedal. When I am coasting down hill off the main mountain where I live, it doesn't even change the avg MPG where as my 2019 ram says 99.9. Only way to get actual MPG is to fill up truck, and drive around. When you go and fill up, you take how many miles you drove divided by how many gallons you put in. EX: 286 Miles divided by 10 gallons of gas you filled up equals 28.6 mpg. I avg 15-17 mpg in my Denali XL.
BG1988
Chevy sucks.
my AVERAGE mpg is pretty close to actual with in about 0.1 to 0.2mpg
with a completely Faulty burned out hybrid battery
i'm getting 25.5 to 27.5mpg with AFM enabled..
24.5 with V8 mode 6.0L engine
This is with the A/C on 2 (67F) setting and recycle..
RST Dana
OH
I can’t drive 55.
Chevy sucks.
Maybe new catalytic converters are in your future?
If your average speed for a tank of fuel is below 21.2 mph, that's 100% city driving according to Uncle Sam and these big V8s don't get great mpgs in the city but you're only burning about 1.5 gallons per hour at this rate. Wait until you refuel before making the calculations. I can often hit the highway with a range of 85 miles, drive 100 miles and still have a range of 50 miles when I get home.
If you know how much she burns at speed, you'll never want for fuel.
Does it make sense to drop $100K on a new one for 2-3 more miles per gallon? Or give up that big, safe, comfy truck for a little death trap rice burner?
I doubt you burned much more than a gallon for that run.
Devlin
Our trucks are generation before yours. We don't have AFM or hybrid. 2006 Yukon Denali XL is also AWD and the windows sticker says 14-17 mpg.
BG1988
they had a hybrid for the GMT800 you just don't know about it
it was equipped with a 5.3L engine
it had a 48Volt system with large lead acid batteries
were comparing apples to apples
the transmission for the 2mode hybrid is basically a souped up 4l60E with 3 additional Planetary Gear sets(one for reverse gear one for EV mode and a SUPER highway gear ) and no starter or torque converter(the transmission is the starter) AFM isn;t anything new from GM for it's V8 engines see cadillac 4-6-8... i got 4 standard speed gears like you do..
at 80mph on flat land the engine is barely at 1700 rpm or 1,000 RPM (on a down hill depending on SOC)
it's a powerful 80HP 360 volt starter with a enough power to blow apart both the engine and transmission in one go, "if things go wrong"... :emotions33:
also the two mode hybrids hold the world record for the fastest engine start time... "Instantly"
nonickatall
Germany
When I see what I save in repair costs compared to a "modern" German car, or what I save in depreciation compared to a new car, I don't care about consumption, at least if it's technically OK. that's why I count in:
Smiles per gallon :cool:
p.s the good thing in germany is, that we have lpg gas. I have a lpg system in my truck and that means that i drive compared to gasoline appx. 31.4 mpg
You don't use that in much the US or? Is my information correct?
BG1988
i think there is an app that can turn off the engine at higher speeds instead of the limited 30mph i wish i had something or a way to unlock the speed because I could fully take advantage of having the engine off for miles at a time and boost the mpg into the 40-50 range.. i would be able to take advantage of the down hills obviously i would need a new battery such as one of those lithium batteries they made for the tahoe.
imagen how much mpg we could get with one of those tesla batteries..
the best i can do is like 3 miles but only limited to 30 mph (on very mild down hill)... even so that is good for an expired battery ...
I guess @Cartier16 must have taken a deep breath and now all is Nirvana with his "Sucky Chevy" and "Cheap GM Crap". Nothing better than a Tahoe/Yukon owner that vents here and yells for help and then disappears. I hope he shares how well it is going with his new PRIUS.
adventurenali92
Big Bear Lake, ca
I live in a mountain ski town as well with a 2006 AWD Yukon XL Denali. I don’t even really bother thinking about fuel economy when I’m home in the mountains cuz it’s all around town driving with stoplights and we dont go more than 45 miles an hour anywhere cuz we can’t really lol.
Whereabouts do you live?
blackelky
Chevy sucks.
Yes a 20 year old suv will get bad gas mileage...obviously its a 8000 lb brick made for towing with a big family. The fact that it's still running strong at 180k should be enough. That's amazing lol....yeah a huge v8 SUV gets bad gas mileage who would've thought
B-train
Agreed. Also to note, it's only a 15 mile commute with some highway and stop and go. The first few miles of either direction are going to be in warm up mode, then factor in starts and stops, etc. But a 6.0L awd truck is definitely better suited for a trip from WI to FL - cruising along at 70 mph.
Maybe he should try and time lights better? That can make a huge difference in itself, speaking from experience.
But, if his calculations ARE accurate, then there are other issues.
Mudsport96
40.923,-89.488. Illinois
Yeah, coolant sensor/incoming air temperature sensor. Something. Hell the incoming air temp sensor on my old work truck went bad, but was still good enough to not throw a code. Made the truck so rich it killed the O2 sensor and those 2 combined took it down to 5mpg. And at that point if I wasn't in 4th gear by the time it got to closed loop mode. It would stall without throttle. So either his calculations are off, or something is busted....bad.
a1parrothead
