TPMS in Trailer
Vladimir2306
Hi all. I was trying to install tire pressure monitoring on a trailer. I bought tire sensors the same as in the Yukon. Installed them in the wheels of the trailer. I'm trying to register from, but the car does not see them. I tried in two ways, and by reducing the increase in pressure and using a scanner. The scanner sees the sensors, but the car does not. Maybe there are other pressure sensors? Or is there some kind of tricky activation method?
Chad G 1979
If i recall correctly, there is 2 versions of the ts sensors and these vehicles use the new version which uses a different frequency? However i am not positive on what the difference is between the two. There should be a thread about ut here somewhere and they habe the proper gm part number for the ones you need.
Vladimir2306
Vladimir2306
Unfortunately, I did not find such a thread
23 Yukon Ultimate
Bronx, NY
2023 Yukon Denali XL Ultimate towing Sloan Kwik Load roll back trailer 7 X 20 10,000lbs
I am trying add those sensors 86803857 on my trailer into aftermarket wheels (Sendel wheels) I call Sendel and they are not sure it fits their value stem hole. Has anyone installed those sensors in aluminum aftermarket wheels any brand
WalleyeMikeIII
Sunny and Snowy Minnesota
Your question is unclear…but I installed the GM trailer tire pressure sensors, P/N 86803857 in the Aluminum 15” weels on my Ranger Boat trailer with no issues.
23 Yukon Ultimate
Bronx, NY
What brand wheel? Sendel wheel Co. Said that they didn't know if that sensor fit their wheel. I'm looking buy wheels for my trailer and want to add the sensors in the wheel
23 Yukon Ultimate
Bronx, NY
That's not the issue its the collar that holes the sensor in place on the wheel on the sendel wheels. The HI spec wheels the sensor will work but it's very close to the beed and could break when they install tire but they make a relocation kit part # DA416. from dill valves. Thank you for your help.
CKendrick
