Stop leak for heater core?
mikez71
Haven't noticed my coolant level dropping, but I have been smelling coolant for about 10 days now. Usually when first getting in the car. Smell quickly disappears, usually catch one or two good whiffs of it before I can't smell it anymore. Running the hvac fan I can't smell it coming through the vents at all. Heater t's are dry, and any grime that is on the pipes does not smell of coolant.
Thinking about using stopleak of some kind. Leaning towards blue devil or prestone. Any suggestions or estimates on how long stopleak repairs can last?
It's gotta be a tiny tiny leak that seals when hot and opens as it cools leaving a tiny amount for the next startup. A couple days I didn't notice it, then it came back.
Also thinking about bypassing the heater core..
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Could be a Tee fitting at the heater core connection ready to jump the shark on you. Or a slow weep on the radiator tank. Small enough not to drip on the ground but enough to get a whiff.
didn't you post about this already?
if you are 100% certain it is the heater core, you could run some stop leak thru it but I would isolate the heater core from the rest of the system while doing it.
easily done by removing the t's and connecting hoses to the heater core and some kind of cheap harbor freight electric pump and a bucket
mikez71
mikez71
yep, that was me. figured id watch it for a week, gotta be heater because i only ever smell it inside. somewhere i heard gm uses bars leak tablets at the factory..?
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Barr’s Pellets are the one for me. One bottle usually seals it nicely.
mikez71
mikez71
Awesome! Yep I heard those AC Delco are rebranded barrs. Will go with delco anyhow. Thanks!
me51
Germany
Use the AC Delco Radiator Tabs.
ACDelco GM Original Equipment 10-108 Cooling System Sealing Tabs - 4 g (Pack of 5) https://a.co/d/dkhkvmg
I thought GM only used those for the Northstar V8 that was famous to leak everywhere. Remember that they will discolor the coolant a little bit, and one application supposedly is enough for the lifetime of the vehicle. You are not supposed to add more when you replace the coolant at some point for example.
mikez71
mikez71
Sounds like it may need heat, tells you to run engine for 15-20 mins.. that and pressure will be missing if i isolate and manually pump? Also since it seems to leak when cold and sitting overnight, Im wondering if it will work now.. I think I'll chuck a couple tabs in the heater feed line.. maybe a couple times. not worried about radiator clogging as its old and due for replacement soon..
mikez71
mikez71
good to know, thanks!
mattbta
Frisco, TX
4.8 5.3 5.7 6.0 GEN III Engine Cylinder Head Cup Plug Coolant Leak
The following diagnosis might be helpful if the vehicle exhibits the described symptoms in the PI.
Condition/Concern:​
A customer may notice a coolant leak from the cylinder head cup plugs of a GEN III Engine.
Recommendations/Instructions​
If there is evidence of a coolant leak at the cylinder head cup plugs, the area should be cleaned and inspected to determine if an actual leak is present or if it was only a coolant stain. Some engines are built with cooling system sealing tabs. If only a stain is present, it may be the result of the cup plug seeping during the first 15 minutes of operation when the engine was new. The seepage may have occurred before the factory installed coolant tabs dissolved and sealed the plug to cylinder head area. If an actual leak is present, the cooling system should be drained, refilled with a 50/50 Dex-Cool mixture and 4 small sealer tabs. Small coolant tabs are available in packages of 5 (4 oz. each) and the part number is 12378254 [in Canada, use P/N 10953473 and add 1 1/2 pellets]. After filling the cooling system, the vehicle should be operated for at least 15 minutes so the area can be inspected for leaks again. If the cup plugs continue to leak after installing the sealer tabs, new cup plugs should be installed as follows:
  1. Lower the coolant level so there is no coolant in the cylinder heads.
  2. Remove the cup plugs and clean the bores.
  3. Apply Primer N (Loctite product number 7649) to the new cup plug.
  4. Apply Loctite 620 adhesive to the cup plug bore in the cylinder head. By applying to the separate substrates, you avoid any cross contamination of adhesive and accelerator. This will also prevent any potential precuring of adhesive that is applied to an activated surface. The vehicle should be allowed to sit for a minimum of 1 hour prior to refilling and testing vehicle.
Granted, this is Gen 3, but even then they could come from the factory with the tabs.
mikez71
mikez71
What's the deal with the heater T's? one white, one black, 111mm and 113mm. ? Can I get both black?
NVM found it
white one is a 90 degrees and black one is slightly angled from 90. Ordering SKP brand from rockauto(has a heart icon next to them..?) where both are black.
Buford bubba
