Help- lights- stabilitytrak, stability control, abs
RockGMC2008
Hello all!
I'm new here - only mechanical basics for me-
Currently took a road trip to help my mom-
Had My GMC 2008- 139,000 mile- yukon xl checked through, oil change, tires balanced before leaving home.
20 miles into trip- After balance still had a little shake felt like one of tire a was not balanced well. No light on no sounds
600 miles in - no sounds- riding same- light came on - stabilitytrak, stability control, ABS. Drove 10 mile to closest GMC dealer- when slowly down on interstate truck felt like bucking - bucked when pulling into parking stop at dealer as well.
Was told by service department- abs /wheel speed senior was bad - causing light
They fixed that and I had them rebalance the tires. Asked them to check it for any other concerns.
They stated no other concerns.
Back on road- 75 miles in- light came on- grinding sound like unbalanced washer machine -
Towed remained of trip to closet GMC dealer by my moms.
Dealer service dept - states oh my God that thing is terrifying- completely locked up pulling in to shop. Metal on metal-
Needs both axels- and entire hub assembly replaced. I told them if that's the case to replace both hubs and both axels.
Began work today - dealer states when they took off driver side front wheel hud literally fell off and was crumbling. Terrifying- stating I was very close to my tire coming completely off on the interstate
Endangering myself and everyone else on the road.
* Still need to get me and mom to my marine son's house and back home. Another 1500 mile ish.
?s
Does all this sound right?
Is it really possible for all that to happen in 75 miles from first dealership working on it?
I'm I crazy or should the first dealership service department have been able to see warning and damage signs ?
Appreciate any feedback?
Thank you in advance
Also I a female so often get the stupid - calls oh you really need to replace your wipers and other stupid crap. So I try to educate myself as must a possible
R
RockGMC2008
Geotrash
Dave
Richmond, VA
Hello all!
?s
That hub looks original to me, so I would say the second dealer gave you accurate information. Perhaps the first dealer replaced the hub on the other side?
Welcome to the Forum from NH.
Pics of the truck, please.
B-train
That is definitely shot! They were correct in their assessment. Also, your ABS stuff was caused by the tone ring either contacting the sensor, or moving out of range. By the looks of it, it was hungry and ate the sensor for lunch.
As for the axles being bad, that's hard to say. If the hub was moving all around, it could have put extra strain on the CV joint. Luckily axles are affordable and easy to replace.
All around an easy, straightforward repair. Any competent mechanic should be able to knock that out in short order.
R
RockGMC2008
First dealer states there was no damage and replaced the abs/wheel speed sensor and balanced tires.
R
RockGMC2008
R
RockGMC2008
Thank you - it's currently at the second shop.
I just can't believe that the first shop changed the wheel speed sensor and balanced the tires and could not see any warning signs of this? And all that damage happened in 75mile after leaving the first shop? Is my thinking wrong?
R
RockGMC2008
I feel pretty confident in the second shops assessment- but feel the first shop could have prevented some of this damage and not put me and everywhere person on the interstate in danger?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Wow! Thank god that didn't come apart on you on the highway!
bad hub could have been overlooked by the 1st shop or maybe it was on the edge of going bad and it only showed signs of the abs being funky, it is rare for just the "sensor" to go bad, usually that is your first warning sign that the hub is going to fail.
I have had a hub go from a little noise to full on metal on metal grinding in less than 50 miles so it is possible.
B-train
Your thinking isn't wrong. A good tech would've had an ear or feal for it. Unfortunately, the days of good techs aren't what they used to be. A test drive should've told them so. They probably just looked at the work order and did the easiest fix to make money. FLAT RATE doesn't ever give the best results.
Been there, done that, have a few t-shirts (that's why I work in power generation now). Good techs will go the extra mile to make sure there isn't a comeback. Unfortunately, it seems as though the comeback game has gotten skewed.........most like everything in today's 1 hurt feeling world.
In the future use your senses, like you did, and just learn what your truck feels,sounds,handles like and you will tune into things amiss.
R
RockGMC2008
Thank you
worleytrev93
