2021 Yukon slips when accelerating.
Asercey80
2021 Yukon seems to be slipping or making a slip bump sensation when I am stopped and start to accelerate. At first I thought maybe it was because it’s always rainy where I live but we just had knee tires put on and it is doing the same thing. Any ideas?
thill466
Did you ever figure this out? My wife's 22 at4 has a slip/driveline slack on acceleration 1 our of 10 times from a dead stop.
tom3
Not sure on the newer stuff but being just a bit low on trans. fluid can cause this on some transmissions, Mopar stuff for sure.
coachhomer
My wifes 2021 just started doing this and I was hoping to find some information on here. I hooked it up to a scanner and the trouble code I received was U043A Invalid Data Received from Suspension Control Module B. Will be searching and get back with any additional info I find.
thill466
Any luck finding your issue?
thill466
Not yet. Holiday weekend but ours seems to be getting worse. Will definitely report back with any findings...
FWIW, I noticed my wife's car was in "auto". I know GM claims it wont damage it to leave it in auto, but obviously there is no need to leave it in auto for daily driving if the car is a pavement princess. I switched it to 2wd, and could not get the slight random thud to replicate. I only drove it for 15 minutes, once I'm able to drive it more I will report back if that solved the issue. Would be interested to know if y'alls is also in auto or 2wd when you had the bump?
@Asercey80 @coachhomer
steiny93
There is another post about slipping type behavior; I did a quick search but didn't find it. Root of the issue was the OP had been running in Auto for a very long time.
Basically, Auto in the dry accelerates wear in the drivetrain and it feels like slippage.
coachhomer
So funny. You beat me to it. That was my wife's issue. Never noticed it.
bert6839
We are having this issue and I'm curious if it's the auto air suspension. We are also having a delay and small thud when in park and shifting into reverse. Feels like it's coming form the drivetrain after the transmission.
DontTaseMeBro
lol, well glad it's resolved! Drove my wife's car for an hour and a half yesterday and the bump was gone.
I’m so glad I found this thread. This sound has been driving me crazy for the last few days. Made me super paranoid considering I just changed the driver side CV axle. Anyways, just checked which mode the vehicle was in and what do you know - auto. Hopefully this gets rid of this sound!
ETA: still can hear it. Gonna check this next:
I can definitely hear it coming from the rear.
ETA2: driver side rear sway bar link upper attachment was loose approx a 1/4-1/2 turn. When I tried to tq the nut, the bolt spun. Had to use a wrench to prevent the bolt from spinning in order to tq it down to 74 ft-lbs. Drove it around the block and so far I don’t hear the clunk. Hope this was the final fix.
DontTaseMeBro
Mine does the same thing regarding the thud when going into reverse. My 2020 Expedition did the same thing as well. I’m thinking this is normal.
BadDaddy2003
