Grinding noise
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yes, it can happen, but that also could be left over from the old belt. Best if you post pics here of what you are seeing.
On the part where the belt is gripping the pulley?
it can happen from wear or if the pulley is a tiny hair out of spec maybe if it does it's usually just from a outer edge of the belt, my alternator pulley has done that before if it is a lot it might be a concern but it's just a tiny bit I wouldn't worry about it.
like stated post some pics and we can help make a determination, you just click on the photo frame above to the right of the chain links
iboughtatahoe23
iboughtatahoe23
Update: there was a spacer behind the pulley that was making it stick out just a hair to far… (the spacer, screw and mount were from the old pulley)
I removed the spacer and reinstalled the new pulley and now the belt sits correctly on the pulley with no over hang.
Edit: Here’s what I did
mikez71
So long as the bearing spins freely, I would say NO. I looked at my old bearing, and it had a much thicker spacer. Probably goes with whatever bearing they decided to use in the pulley.
iboughtatahoe23
iboughtatahoe23
You need to switch it on or off when you hear the noise to see if the noise changes/goes away.
No change, it's probably something else.
Second easiest thing is to take the accessory belt off. That would eliminate idler pulleys, alternator, water pump, power steering as possible culprits.
Maybe try moving your phone to different areas and record away. Get some good tape..
i thought changing the idler pulley fixed it. But it’s back
iboughtatahoe23
iboughtatahoe23
Guess I’m not sure what else. I was gonna check the flexplate, or I know someone mentioned fuel rails and such etc, I have been trying different fuels. Comparing e85 and 91. Idk if that affects it or makes it worse. I spun the pulleys that spun freely and they didn’t make any noise. But like I said I still changed the idler pulley.
I suppose if it gets worse I’ll take it in. Last time they couldn’t hear it. I even showed them a video of it loud and clear and they still said to see if it gets worse.
iboughtatahoe23
iboughtatahoe23
So if it’s speed dependent…. And seems to only happen around 25 mph and stops as soon as I shift around that speed, I am really afraid it’s transmission related or torque converter related.
But if the issue has persisted this long without affecting driveability in any way really. Than how serious is it.
iboughtatahoe23
iboughtatahoe23
iboughtatahoe23
iboughtatahoe23
Anyone know if I can see the starter touching the flex plate through the inspection port? Something did seem really close.
Doesn’t appear to be scratching anything in the photo.
Also hear the intake manifold can rattle?
wjburken
Eastern Iowa
Your intake manifold is plastic and on top of your motor. I have never heard of one rattling. If it was, you would have a myriad of codes.
The stamped heat shields on the exhaust manifolds can rattle as well.
Nope. Not seeing any signs of wear from the starter in that photo.
Durobans
