Any particular reason why 13.677 gallons?
Because 13/6/77- The 13th day of June in 1977. It was the day that James Earl Ray was recaptured.
Lolnahseriouslythough, it was an even $35 and about half a tank. Felt like a good stopping point to me. I was gonna do $30 but got sidetracked and went over so I went to the next $5 increment. It also being about half a tank satisfied my OCD. Unless I'm on a road trip, I just get 1/4 to 1/2 a tank cuz it sits so much. This way, I'm always getting fresh gas.
Alternator delivered, three days late.
As expected, it was almost out of the box. I was half-expecting a broken mounting ear. The pulley (actually the clutch) was the part almost protruding, but still covered in bubble wrap:
It seems fine, but has a very slight wobble. It spins smoothly and the clutch works. If the clutch wasn't such a PITA requiring special tools, I'd remove it and check the shaft for runout. I'm gonna spin my current one and see if there's any wobble in hopes it's something common and harmless. No dents in the edge of the clutch. I'd think a hit hard enough to bend the shaft would put a sizeable ding in the clutch shell. I'm gonna look for good pics of that center cap removed to see if the shell is as thin as I think it is to confirm my theory/hopes:
Part number 13539728:
I'll probably chop this ear off. Or, keep it and repurpose the bracket mounted to it somehow. Maybe a catch can bracket for that factory-original effect?
I see the harness plug as a bonus. I'd like longer wires, but these are workable should I need them:
Ad said 6,000 miles on this unit. I believe it.
89Suburban
Bull in the china shop
SE PA
Sam Harris
Reminds me of an OEM water pump I ordered from Summit. I received it, and there were several holes in the box. There was a slight dent on the end of the large hose flange. That thing got kicked around pretty good, to cause damage there, where the flare was! After speaking with them, finding out they had no substitute, I went with it, after they promised to make it right if I had any problems.. whaddya know. After installation, the sucker leaked. I’m glad it revealed it’s faults right away, not 10k after being installed.
That's about what I was picturing. It being a few days late, I thought for sure it was cuz it got hung up somewhere in the journey cuz the box tore open and alternator fell from at least waist high. It came from Tyler, TX. Its time in transit was doubled, possibly meaning it was subjected to twice the movement/abuse.
Well, this is a cluster. This alt has a totally different mounting arrangement than what I need. I went off the seller's description, which listed a part number of an alt that has the correct fitment. Their pics just showed the sticker on the alt so I didn't bother to dig deeper. Not when I had such a bōner for the super low mileage. Between the description discrepancy and their poor packaging leading to shipping damage, I emailed the seller requesting replacement or refund. On to the pics-
The original alt is like "Tab A" that goes inside "Slot B" of the accessory bracket on the engine. The new alt has the "Slot B" arrangement:
So, it'd be like this:
Which is basically this:
Also, the main lug interferes with the EVAP purge pipe:
Other comparison photos just cuz:
Your eyes are not deceiving you. The pulley on the new alt is smaller.
Stock:
New:
I just kinda eyeballed it, but I think the center of the pulley is located further away from the mounting points to make up for the smaller diameter. Worse case, I bet I could make it work. But I'm not interested in such a project and it'd be too easy to screw up and then I'd be plagued with belt wear and/or noise issues. I hope the seller does the right thing.
bawlz09
