Wiring harness help needed
AmunRoo
Chicago
All right, I need some help trying to pinpoint the path for a ground wire from the bank to coil harness. This is for the connector on the engine harness that feeds the oil packs for Bank 2. I don't have ground. I'm getting misfires on all four cylinders because I have no spark. I spliced in the ground direct from the battery to the ground wire connector side of the harness. I tried looking in all data but couldn't find what I was looking for. I'm trying to find the path of that ground wire to find out where it terminates so I can have ground once again. Otherwise I'm just going to splice it into another ground and call it a day LOL
As always, any and I'll help is greatly appreciated!
you could try the gm upfitter website otherwise @swathdiver may have it.
I would would probably just ground it to the block myself in the meantime.
G102, lower left side of the engine.
How did you locate this? I'm still trying to grasp how the upfitter .pdf is organized.
AllData interactive wiring diagram.
johnsonwillie199
