donjetman
- Joined
- Oct 22, 2018
- Posts
- 2,010
- Reaction score
- 3,696
Here's the lastest UOA for our 07 Yukon Denali w/all aluminum 6.2L L92 (non-AFM) w183k miles running premium gasoline.
This oil was installed April of 2022. It was Amsoil ASM 0w-20. Full flow oil filter was Fram Ultra XG10575. Bypass oil filter is Amsoil EaBP90.
DIC: 31% remaining. Averaged 17.4 mpg and 47 mph. 50% hwy, 50% local. Burned 491 gals in 182 hrs = 2.7 gph.
Samples #1 & 2 are the same load of Amsoil ASM 0w-20 with a 1/2 qt of makeup oil added between samples
Sample #3 is Kirkland 5w-30
Samples #4 & 5 are different loads of Mobil Delvac1 ESP 5w-30
Sample #6 is Mobil Delvac1 ESP 5w-40
Between samples #5 & 6 a plastic heater hose t-fitting broke which resulted in a short overheat event.
This was my first time to run any 0w-20 oil in anything. Gas mileage locally is 16.0 mpg and 19.0 mpg on the hwy. This is a noticeable improvement. I'm getting 20-30 more miles per tank (25.5 gals). Or it could be that I changed all 4 O2 sensors. I drive the speed limit (conservatively), no towing, no hot rodding.
I changed the oil to HPLoil.com performance synthetic 0w-20, and the full flow filter to Fram Titanium FS10575. The bypass was drained and reinstalled for its fourth run.
What say you?
What say you?
