Another UOA = Used Oil Analysis, 07 Yukon Denali 6.2L w183k miles, Amsoil 0w-20 w/8.5k miles
donjetman
Here's the lastest UOA for our 07 Yukon Denali w/all aluminum 6.2L L92 (non-AFM) w183k miles running premium gasoline.
This oil was installed April of 2022. It was Amsoil ASM 0w-20. Full flow oil filter was Fram Ultra XG10575. Bypass oil filter is Amsoil EaBP90.
DIC: 31% remaining. Averaged 17.4 mpg and 47 mph. 50% hwy, 50% local. Burned 491 gals in 182 hrs = 2.7 gph.
Samples #1 & 2 are the same load of Amsoil ASM 0w-20 with a 1/2 qt of makeup oil added between samples
Sample #3 is Kirkland 5w-30
Samples #4 & 5 are different loads of Mobil Delvac1 ESP 5w-30
Sample #6 is Mobil Delvac1 ESP 5w-40
Between samples #5 & 6 a plastic heater hose t-fitting broke which resulted in a short overheat event.
This was my first time to run any 0w-20 oil in anything. Gas mileage locally is 16.0 mpg and 19.0 mpg on the hwy. This is a noticeable improvement. I'm getting 20-30 more miles per tank (25.5 gals). Or it could be that I changed all 4 O2 sensors. I drive the speed limit (conservatively), no towing, no hot rodding.
I changed the oil to HPLoil.com performance synthetic 0w-20, and the full flow filter to Fram Titanium FS10575. The bypass was drained and reinstalled for its fourth run.
What say you?
donjetman
donjetman
@swathdiver .
We don't really do much "city". We do "local" rual driving where we live (out near the sticks). Sometimes I get stuck in stop and go traffic during rush hr, so we're not that far out.
Our "hwy" driving is mainly the 1000 miles each way between our TX and CO mtn home. It easy for me to remember how many times I've done that.
Recently (since this UOA and switching too HPLoil.com 0w-20) we've did a "hwy" trip to the CO mtn home (10,000' asl) and back (1000' asl). We fought a headwind going and got 17.4 mpg. We had a tailwind coming back and got 19.8 mpg. Averaged 66 mph each way.
I had always wondered if there was a way to determine the amount of city versus highway driving time with each tank of gas. I could calculate the mph easy enough but on average, over time, how much time was spent doing each?
I went to fueleconomy.gov again and went to the section where they calculate mpgs and they use 21.2 mph for 100% city driving and 48.3 mph for 100% highway driving. So adopting their logic, I made a chart in Excel and use a formula to interpret the city vs hwy useage based on the mph per tank of gas. Then mpg and gph charts for each were made.
So having said all of that, your 47 mph average works out to 95.2% highway driving.
donjetman
donjetman
It's easy math: Divide miles by hours. DIC provides the info.
It's a 3rd vehicle (2 drivers). We only drive it "locally" if we're going 30 miles or more.
About 60% of our TX - CO - TX trips are done in the Yukon, the other 40% are done in our Prevost bus/mh.
I'm thinkin about replacing the Yukon with a C5 Z06 Corvette.
5StarCustmSolutns
Almost Heaven, WV
What say you?
I say WOW....impressive
I've no idea what levels of these elements would be considered low, acceptable, or excessive when testing 3/4 life motor oil? I found this trying to get some feedback on making the engine oil switch from Mobil 1 to Amsoil and Trans Oil switch from Valvoline to Amsoil... But just based off the results, it looks like each of them was strong in different areas?
Would have to think you'd want aluminum and iron to be low in an L92, same as I would in my all alum LC9?
I originally thought the Kirkland looked the best overall, but I think the Amsoil changed at shorter intervals may be a touch better??
Bottom line: I pray daily to grow into a man this thorough and meticulous! Nice work
donjetman
donjetman
Engine suffered an overheat event (Broken heat hose plastic T) Dec of 2019, should have change oil immediately. Hi iron etc afterwards.
dkad260
I don't know enough about an OCA to determine what is good or bad, but I'm curious why you chose a 20wt oil for a 180K motor over the OE spec 30 wt?
Does the manual say a 20wt is ok for that year engine?
I know Amsoil is good stuff, I'm just thinking on the shear over time by beginning with a 20wt oil over a 30wt.
Is your Yukon AWD or RWD? Tires properly inflated?
New upstream O2 sensors over worn sensors can play a part with fuel economy.
Another thought, if you compare highway MPG in the dead of winter as opposed to spring/summer, I agree, wind plays a big part. Cold, dense air is harder to push through, if you have flown light planes you know what I mean.
Overall it looks good, but if the iron is up over your other oil changes, what comes to mind is also the crankshaft journal, along with the before mentioned cylinder sleeve.
Again, above my pay grade, by personal thought is to stay with a 30wt...but that's just me.
donjetman
donjetman
The report in post#1 shows that the oil didn't shear.
AWD and always properly inflated which helps me achieve the great reliability and gas mileage.
as I stated in post#1 I changed all 4 recently
I'm a light aircraft owner (25+ yrs) and a retired pro pilot.
Iron was much higher in reports 3, 4, & 5 when I was running 5w-30, but as I stated in post#1, there was an overheat event due to a broken heater hose T fitting shortly before sample#5 was submitted for analysis.
I learned on BITOG forum how thinner viscosity oil can flow a higher volume thus doing an arguably better job of carrying heat away and lubricating.
Like I said in post#1 = I drive conservately, I don't tow or hotrod.
I'm not certain what my next oil change will be with.
dkad260
Yes, I was just reiterating that point.
I was basing my iron statement of the Blackstone comment of your 0W-20 OCA, about the increase of iron. They basically said don't be too concerned and I trust that, again, over my pay grade.
Again, I think the OCA looks ok, I was just giving my $.02 on using a 20wt oil in a 180K mile LS engine, might be perfectly fine, only a different viewpoint.
donjetman
donjetman
no. My owners manual was written in 2007. A lot has changed since then, oils too.
If crankshaft was shedding iron lead and copper from the bearing(s) would be thru the roof long before the iron from the crank shows up.
dkad260
I would agree.
I was more or less adding to Dustin's inquiry on where iron would be found in an aluminum engine.
donjetman
donjetman
I bought a stock 02 C5 coupe, only 60k miles. Rides smooth and gets great gas mileage.
Believe it or not? the C5 is gonna replace most of our Yukons trips of going back and fouth,1000 miles ea way, several times a yr between our 2 homes (TX & CO mtns). We no longer have large dog(s).
We'll still need the Yukons awd capability in the winter on the CO end.
Geotrash
Dave
Richmond, VA
Believe it or not? the C5 is gonna replace most of our Yukons trips of going back and fouth,1000 miles ea way, several time a yr between our 2 homes (TX & CO mtns). We no longer have large dog(s).
Sorry to hear about the dogs, Don. :-(
enigmaspeed27
