Didn't like that back to back 90 for flow anyway, glad it didn't work lol
Valid point. I disregarded this factor due to my low power levels.
Do like that gto hose tho, I've seen it before and thought it worked good but forgot where it came from
Got this one off Amazon. I think it's the '04/LS1 version- about 7/8" longer than the '05+LS2 version.
Functionally, I'm satisfied with how it all fell out. I'd like to remove the Russell hose and heat it to "lock" it in that looped position. I was looking up temperature ranges of PTFE (hose material inside braided part) and Viton (O-ring) materials last night. 350° should be sufficient and plenty safe.
Got home this afternoon and immediately uploaded those changes since I was in a rush to get out to take Kin to dinner. Watching the scanner, it's floating between 11.8% and 12.2% alcohol content. Test tube shows 10, maybe 11%. So, it's MUCH more accurate right away. I'd rather it read a point or two high than the 7 to 20+ points low. I'm currently at 1/8 tank of 93 E10. I'll time it to be on fumes as I reach the RaceTrac with E85.
I'm calling it a win. For those keeping tabs (@kbuskill):
Sensor: ACDelco 13507128- $53 on Amazon
Plug and pigtail harness: Hoypeyfiy (actually Delphi)- $8 on Amazon
Braided flex hose: Edelbrock/Russell 651120- $31
randeez
south florida
i grabbed one of the gto hoses, going to try and use on caddy. the fuel line for it come up on the passenger side, makes a 120* turn, cuts across the top of the sc, and then 90s into the hard line that goes to the hpfp. its retarded.
im hoping i can put this on the hardline to the hpfp go behind the engine and put the sensor, and hoping i can massage the stock line to turn behind the engine
mattbta
Frisco, TX
That's awesome. Meanwhile, my '04 flex sensor is crazy expensive. RA has it at $380. :eek:
Thankfully, mine is still reading accurately. Massive knock on wood.
Plenty of them in the Upulls around me. Last time I was at one I saw 5 or 6; easy to get to with the engine and tranny out. If they're any good!
Rushed home yesterday to get cleaned up to head out to Kin's school play. Running with no time to spare, I hopped in the Tahoe and turned the key- nothing. Battery couldn't have been more lifeless if it were a ghost.
So, y'all remember that time I installed a subwoofer and forgot to run a remote wire so I tapped into the power wire for the power fold/tumble seat? Yeah? Well, I forgot to turn it off when I got home Tuesday night. I hooked up the charger and stole the work van to make it to the play. Afterwards, Walmart was the only place still open. After reading some reviews, watching a Project Farm video and calculating other factors of my current situation, I went to Walmart and picked up the best they had. I've always gotten Super Start batteries from O'Reilly. But this EverStart looks identical and was $70 cheaper ($180 vs. $250). Has the same specs, an extra year of warranty, and was cheaper than the SS Premium I would've gotten from O'Reilly. TLE was closed and the lights were off, so I helped myself to the battery rack and dug in the back to find one dated 4/23. Hecho en Alemania:
I had to make it appropriate for Cinco do Mayo, so I added some avocados to the cart. That was my 9:00 Friday night- a car battery and avocados.
I can't ever just do one task. While the battery was out, I decided to finally do something about that crumbly conduit on the main power wire that goes across the firewall to the fuse & relay center. Didn't have conduit, but thought the mesh sleeve I used everywhere else was befitting. If I was messing with that, why not upgrade the wire? I took the fuse and relay center apart to remove the main power wire. All I had enough of on hand was that 4 gauge OFC welding lead I used for my amp power. The main power wire looked to be 4 gauge, just with a thinner jacket than the welding lead. I don't think there's anything in that panel pulling enough amps to justify the hassle, so I just put it all back together.
Before:
Mesh sleeve installed:
After:
I used a piece of heater hose over the portion that goes over the hood strut bracket. It was a friction fit between that and the underside of the cowl.
At this point, all the main power cables are in the mesh sleeve and everything in the corrugated conduit are control circuits. It looks like a lot, but it's pretty much the stock layout, just bigger:
Old vs. new battery comparison:
Got over five years out of that Super Start, abusing it the last three or four. Tahoe cranks faster now and my headlights are dimming noticeably less, as expected. I went for a ~30 minute drive to ensure a solid initial charge. My alternator was supposed to have been here yesterday. But, UPS do what UPS do. ETA is now Monday.
Since the battery had been disconnected for so long and they were relearning, I used my handheld scanner to monitor fuel trims. Also checked the alcohol content- it was still fluctuating between 11% and 12%. This is the sample of what's currently in the tank:
I have about 40 miles to empty and the nearest station with E85 is 22 miles away. I wanna be on fumes when I refuel with E85. So, I could either run some made-up local errands to burn gas or drive like an ass to the next one that's 35 miles away.
a1parrothead
