my memory is crap but i think my 00 had a rubber flap attached to those that covered the area between the airbox and back of the headlight
could be wrong though
Yes behind both headlights and on each side of the radiator.my memory is crap but i think my 00 had a rubber flap attached to those that covered the area between the airbox and back of the headlight
Looks like somebody in the neighborhood is missing their ForSale sign.....TBH, brings joy to see people recycling/repurposing "found" items!I ended up making my own sets for thecopcar and theothertwin using coreten.
View attachment 397596View attachment 397597View attachment 397598View attachment 397599View attachment 397600
Like @Sparksalot I used the same material. Except mine cost infinitely more than his because I had to order it from Scamazon.What are the names/part numbers for those rubbery flappy panels on each side of the radiator that help direct airflow into the radiator?
I've seen them posted and talked about in the forums, but don't know what to search for
@swathdiver @Geotrash
It I recall, I salvaged it from the construction site trash bin.Looks like somebody in the neighborhood is missing their ForSale sign.....TBH, brings joy to see people recycling/repurposing "found" items!![]()
How very green!It I recall, I salvaged it from the construction site trash bin.
I put the grommet on the bolt and popped them right in. Little lube helped but it was pretty much effortless.Grommets. I used FEL-PRO VS 50504 R-1 kit for mine. Two valve cover gaskets and eight grommets. The grommets are a bit of a mofo to pop in. Here's what I did: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1669160
Compensates for the Dino juice his 'HOEs drink!How very green!![]()
Yours? In the GMC?err window switch still erratic,
Over the past week:
Drain and fill Front Diff
Drain and fill rear Diff
Drain and fill transfer case
Install Stabilizer links (front left and right). Mine were completely shot.
These tasks were super easy and I would definitely NOT take it to the shop if you have a few tools and some time..
Looks like I need to replace the rack and pinion so that's up next..
ya I cleaned it yesterday and tested it many times and it was working fine and then today it's back to being intermittent.Yours? In the GMC?
What part numer are these? Sfks website is crap. Assuming they're 4wd right?Installed new front wheel bearings. SKF xtracker hybrids, thanks to all for the suggestions on wheel bearings.
Thanks for the tip.You can buy replacement boots and install them.
I replaced mine with a reman from Rock Auto and it’s been fine ever since.Thanks for the tip.
Unfortunately my R&P is showing signs that it needs to be replaced.
Bumps make the steering wheel shake, sometimes its hard to turn. I can turn it more on one side than the other. All signs that R&P is failing..
