Same as mine that I think I possibly sent you a pic of when I was parts gathering
Here, text or OF private message?
Also, my alcohol level stayed at 21.6% after over half a tank of 100%. Today I topped off from just under a quarter tank and logged it. Bam, 4.4%, but wait. It jumped around from that, to 7.7, then up as high as 28%, then back down to 14 I think. This was in a <5 mile span of logging. So idk
The virtual sensor will take some miles to relearn, triggered when it sees fuel has been added. I think the numbers are an increase of three gallons to trigger the relearn and the relearn takes at least seven miles. The relearn can be interrupted by many factors including hard throttle, multiple restarts and excessive idling.
pwtr02ss
Tennessee
The virtual sensor will take some miles to relearn, triggered when it sees fuel has been added. I think the numbers are an increase of 3 gallons to trigger the relearn and the relearn takes at least seven miles. The relearn can be interrupted by many factors including hard throttle, multiple restarts and excessive idling.
I'm sure iMessage or OF
randeez
south florida
Speaking of trolls...
I bet you know how it works!
all this o2 talk... i went ahead and ordered another denso. ive got one bank that always reads low at idle but cleans up and looks good at anything above. ive chased down dead cylinders changes plugs, wires, coils, injectors cleaned, compression tested every cyl. prob shoulve started with a new o2
Unless I can confirm the ones I have actually are correct (or are a viable option), I'm probably gonna order some of the other ones @swathdiver listed. I've read so much conflicting info on these- both with what part numbers are correct and their position- upstream or downstream. Also read that '08 and maybe '07-'08 had their own part numbers for sensors and Denso was the supplier for those years.
James, can you link me to your "ACDelco smart page"?
randeez
south florida
get the gd flex fuel sensor and quit messing round with the virtual
possible the one i have on bank two is just cooked from pressure/heat. could probably just swap the two and see if problem follows also, but never hurts to have a spare around anyway
True true. Hell, If I can do the sensor how I want, I can have it done for about the same cost as two new sensors. I really wanted them just so I know it's reading accurately regardless of calculating alcohol content. But, I guess they are cuz everything seems to be in line.
I have an intermittent issue with B2 as well. "Insufficient switching". I get it maybe once or twice a year. I swapped the sensors around- problem didn't follow. Maybe it's old injectors. I wanna have the injectors on that spare engine I bought reconditioned and flowed. I've used Injector RX in Houston before. No complaints, but can you recommend anyone?
GMPartsGiant and https://parts-catalog.acdelco.com/acesCat.php?
All 3 of my trucks use the same sensors.
Because some guys were showing Denso sensors in ACDelco boxes, I went into the garage looking for my spares and old ones but couldn't find them. Must be buried in the corner.
What started this was folks getting bad readings and finding out the common factor was aftermarket sensors. Then I compared them online and saw that they are physically different. It's still possible that some Denso sensors being sold are different then the ones sold by ACDelco, like NGK does with spark plugs. Happy to be wrong.
In my racing days, we went through a ton of O2 sensors to keep the motors in top form. They were not heated back then (1 wire) and wore out quickly wen exposed to leaded gas or too much octane booster. We didn't have ethanol back then. We made slightly more power with GNX sensors, guess they were calibrated a little differently.
Texted a parts list, etc. to Hy Hoe guy.
Did some research on the physical sensor conversion. Found there are a few options for pre-made kits from around $200-$300. Found GM sensors (Continental) for ~$55 and plenty of pigtail options for ~$8. Next step is to get under it and confirm a connection method.
FINALLY got that damned HPT to write to this thing. Reset laptop (runs much better!) and completed HPT's online course to unlock the advanced parameters (more of a Hail Mary shot). I was trying to upload an older tune and it kept saying I wasn't licensed. I then just read the current calibrations, edited those and wrote them. I'm guessing the problem was that older tune was done with the MPVI2 and the most recent were with the MPVI3 and those are the only ones that'll work now. I never claimed to fully know what I was doing.
pwtr02ss
Tennessee
Glad you got it figured out. Hpt can be a pain in the ass sometimes...
kbuskill
NE. FL.
Now I have no idea how I came up with that number. Maybe RA? I just checked RA and they list Denso 2344668 as the upstream sensor. They don't list any "GM Genuine" upstream sensors. I have no use for the downstream sensors other than to keep the holes plugged.
Also, RA lists a "GM Genuine 2133866" for the downstream sensor. That's a Denso part number that coincides with what you just posted. Maybe this is how the suspicion that Denso is the OEM for ACDelco/GM Genuine? I'm wondering, with my luck, if I just so happened to rely on RA's info and it was incorrect.
O'Reilly says 213-3866 and 213-4229 are both for downstream for a 2008 Tahoe VIN 0. It says the 234-4668 is the upstream.
Napa guarantees 234-4668, 213-4229, 213-3866 to fit, but doesn't specify position.
The ACDelco Parts Catalog (the one I found) shows 213-3866 and 213-4229 both as downstream.
Screw all this. I'm gonna get Dorman sensors. :p
Swapped upstream O2 sensors today. Out, with the Denso P-B664, and in with the GM/Denso 213-3866/ 12583804. Been having issues with ethanol percentage being calculated to high for a while. Started with replacing O2 sensors a while back to no avail. Replaced fuel pump to see if that would help, and as preventative maintenance, no change. Changed MAP sensor and MAF sensor, no change. I also keep getting a P1174 code almost every time I drive it. Checked and re- torqued the intake manifold bolts, a couple on the driver side were slightly loose, maybe a 1/2 - 3/4 turn. All for nought.
All this talk about O2 sensors prompted me to swap to the "factory original" O2 sensors.
I did notice they are definitely different when I had them out as seen in these pics. OG style has less holes around the side and one hole in the end.
Just figured I would add to the confusion, I mean discussion... lol
I will post later on if this has corrected the issue with the P1174 and the ethanol composition issues. So far no check engine light after driving 75 miles back from my brothers house.
Great timing and looking forward to your alc % results! How are you testing it- test tube with water method? I've never heard of the Denso P-B664 in all of this.
randeez
south florida
Denso 234 4668 is what RA was saying for mine that I ordered :shrug:
randeez
south florida
Do you run E85 on yours and did you switch to the physical sensor?
yes, yes
so no idea how they work with the virtual
well not really, before i switched to the virtual i dont think i ever saw over like 60-65% after putting in the sensor same stations were pretty consistantly 72%-85%
but i dont know what the o2 part no was at the time
yes, yes
I have the same O2s as you, as spec'ed by RA. Maybe they work fine for general engine operation but not for the alcohol calculating part. If I can add the physical sensor in where I want it, I'd rather spend the cheese on that than two new/different O2 sensors and still likely not be as accurate with alco %.
I'll be under the Hoe shortly...
randeez
south florida
i dont think theres anywhere to add it under that already as qdc fittings. i cut mine in right by the abs module where it jumps from the frame to the transmission.
a1parrothead
