InspectahDEck
- Joined
- Oct 15, 2013
- Posts
- 76
- Reaction score
- 66
I have had a PS fluid leak from of 05 yukon for some time, where the leak is coming from the bottom weep hole on the brake booster unit. I purchased the replacement gasket set, but that ultimately started leaking again as well. I decided to purchase a reman brake booster unit (Cardone 52-7370). After installation, there is no leak, but the brake pedal is very light, and is slow to return. Takes about 15 seconds for it to fully return.
When replacing the gasket set in the past, I never had to bleed the brakes. Is this something that needs to be done after a full brake booster unit replacement, or is this a defective product possibly?
When installing the brake booster, I simply disconnected the two bolts from master cylinder, leaving all hoses and attachments in tact on the master cylinder. Have confirmed everything under the dash is connected properly and nothing interferring with the brake pedal returning.
Any thoughts appreciated
