LargER L59 V8 oil filter part number
Marky Dissod
Typically I mix'n'match whichever brand motor oil happens to be cheapest, but only if it's 0W30.
Yday my Tahoe told me to 'Change Engine Oil', just shy of 4,000 miles. Next time I'll change @ 3500 miles.
I am vehemently against using a tiny oil filter. I'd much prefer to use one with extra oil capacity.
Ok if I ask for some part numberS for larger oil filters for my Tahoe's L59?
Since I no longer drive very aggressively, my guess is 0W30 & changing oil and filter more often is more important than using THE ULTIMATE oil and filter, which is why I'm asking for part numberS.
Thanks in advance.
M
Marky Dissod
Read something like this a few times:
GM changed the ACDelco oil filter thread design for Gen 4 V8 engines.
Gen 3 V8 PF46/PF61 used SAE thread. For Gen 3 PF46 is short, PF61 is longer.
Gen 4 V8 PF48/PF63 use metric thread. For Gen 4 PF48 is short, PF63 is longer.
Does that seem right?
S33k3r
Dallas, Texas
Would someone mind educating me on this, please? Why is having a bigger oil filter better? Is it because you can go longer between oil changes? I get that a bigger filter can filter more oil at once due to greater surface area. Anyway, thanks.
M
Marky Dissod
ACDelco PF61
Looking for equivalents. To be clear, I am NOT sure if these part numbers are compatible.
If anyone has any idea if these filters are interchangeable, please speak up.
Fram 9837? or 3675?
Wix 51522?
Mobil1 M1-206?
Seems like it was easier to find the part numbers that cross referenced against any other part number years ago ...
M
Marky Dissod
AC Delco PF61 Equivalents:
GM 19210285 or 25014377? or 25014878?
Fram 9837? or 3675? or 3429?
Wix 51522 or 51045
Mobil1 M1-206
M
Marky Dissod
I wish I had a chart like this for the Gen3 V8s.
M
Marky Dissod
As of today, this is the list I've been able to compile of largER oil filters compatible with ACDelco PF61
AMSOIL EAO64
CARQUEST 85522
CHAMP PH59
CHAMPION OF07
CHAMPION OF30
FEDERATED LF164F
FEDERATED LF487F
FIRESTONE L25288
FRAM PH3675
FRAM PH9837
GM 19210285
GM 25014377
GM 25014748
HASTINGS LF164
HASTINGS LF487
KENDALL K9
LUBERFINER PH922
MOBIL MO5288
MOBIL ONE M1-206
NAPA 1522
NAPA ProSelect 21522
PARTSMASTER 13675
PARTSMASTER 61522
PENNZOIL PZ28
PERFORMAX PO-28
PRONTO PO3675
PRONTO PO487
PRONTO PO5288
PRO-TEC 166
PUROLATOR L25288
PUROLATOR PureONE PL25288
QUAKER STATE QS3675A
SHELL SH43
STP S3675
TEXACO T-43
VALVOLINE VO31
WARNER WPH59
WIX 51522
So far as I know they all share 13/16-16 thread, 4.526" height, 2.921 Top OD, 2.430 Gasket ID, 2.734 Gasket OD
Mudsport96
40.923,-89.488. Illinois
Well since the filter media is the same density/micron rating in both the long and short versions of the Delco filter, more surface area allows it to flow more easily through the filter. You aren't really getting more life per se, but maybe better flow (through the filter) at the same oil pressure.
M
Marky Dissod
M
Marky Dissod
Dumb question:
Would a 2002 Suburban 2500 (/3500?) with a 6.0L,
share its same oil filter with a 2002 Suburban with a 5.3L?
Or would it use a different one?
If different, HOW SO?
Suspect they may be different yet compatible ...
Based simply on Wix offerings by Rock Auto, the 5.3L engine would use the 51042 (or 51042XP) short filter, while the 2500 6.0L would use the longer 51522 (or 51522XP).
I elect to use the 51522 longer filter on my '04 5.3L, just to have more media. My oil change intervals are 5k miles. If I wanted to use synthetic media I'd use the long XP. I don't see any reason to use the shorter filter in mine.
M
Marky Dissod
Based on this response, it's safe to lie to the parts mungqi and say I have an '02 Suburban 2500, then take that oil filter and spin it right on my 5.3L?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yes. If you look at the WIX site for oil filter specs, The ONLY difference between the two, is length. I have used both with absolutely no problems.
Also, look up your own parts and tell them what you want and not what they suggest.
^^ THIS. No need for them to know what vehicle you have or are working on. Saves them time by not having to ask and look up the vehicle. ;)
I look up everything, except for whatever help I need from @915_Tahoe, because I pay attention to any footnotes and sometimes the parts counter person doesn't. I can tell them K1500 and they will say, "2wd or 4wd?" I look up at RA, O'reilly, Napa, AZ....etc. I do cross refences and also use manufacturer's oe sites. When I am going to work on a vehicle, I ask for year, production date, VIN, make, model, 2wd, 4wd, awd, fwd, rwd, auto or manual, coupe or sedan, suv/mpv, country made/asssembled and certain RPO codes....etc. Because I know all that is in the footnotes.
M
Marky Dissod
This is what I've been doing, except when I talk to a parts animal,
they always ask 'describe your vehicle', then I say,
'if I do that, you'll give me the shorter filter, and I want the longer one,
so please stop asking me about my vehicle and gimme a'
one of the following:
ACDelco ......... UPF61R (NOT PF61, NEVER PF61E)
Fram ............. xx3675 (haven't yet figured out which Fram version is good enough ...)
Mighty ........... M159 (these are not bad actually, but only mech garages have them)
Mobil1 ............ M1-206 (like these, but they're never cheap)
Purolator ........ PBL25288 (NOT 25288)
QuakerState ... QS3675A (haven't yet figured out which Quaker State version is good enough)
Wix ............... 51522XP (NOT 51522)
It's actually easier to ask for the oil filter for a Suburban 2500.
If only it were that simple to find out which GM OE torsion bars I can upgrade to ...
BadDaddy2003
