Blancotahoe
Needing Help!
I have a 2007 Chevy Tahoe LT 5.3L V8
Ive owned it for 2 years after about a month of owning had a Cyl. 7 missfire, new plugs / wires, no fix, went down the entire rabbit hole and found a stuck valve, now i sit here today, absolutely stuck, still having a missfire (cyl 1 & 6), EVAP codes, And throwing a “No Communication” on every Control Module (ECM, TCM, BCM) everything i have done below
• New Plugs & Wires
• New Injectors
• New Coil Packs
• New Cyl. Heads (Reconditioned)
• New Lifters
• New Lifter Guides
• New Push Rods
• New Throttle Body
• New K&N Intake
• New Catalytic Converter
• New O2 Sensors
• New Terminals
• New Fuses & Relays
• Replaced Entire Engine Wire Harness
• New Cam & Crank sensor
• New MAF Sensor
• New Intake Manifold Gasket
• Cleaned,Replaced,and Added Ground Wires
___________________________________
A few pointers to help that i have found out,
• All mentioned items have been tested
• I own an Matco Scanner, Multi-meter, etc to run tests
• When putting Scanner into OBDII port dash goes wild, and truck drops RPMs and Bogs/ almost dies
• Truck will sometimes retract Check Engine Light when driving
• Not getting power to Fuel Pump Relay, having to jump it to run it
I am STUCK to say the least, bought a glossy turd if anyone can help, or have suggestions please let me know, ive been suggested by a few to replace the ECM, but i dont want to just throw money and pray i want results
Thank You!
B
Blancotahoe
Welcome to the forum!
Have you pulled the underhood fusebox top (that holds the fuses) to inspect and clean the harness connections that are underneath the fuse holders?
I have not checked that, will check when i get home from work, another thing i forgot to mention is the erratic gear changing, test driving it i stood on the gas (Was seeing if the CEL would pop on) and it would drop, and up a gear about 3 times before i let off (maybe 5 seconds max?)
B
Blancotahoe
Needing Help!
• New Plugs & Wires
• New Injectors
• New Coil Packs
• New Lifters
• New Lifter Guides
• New Push Rods
• New Throttle Body
• New K&N Intake
• New O2 Sensors
• New Terminals
• New MAF Sensor
Thank You!
Another thing i forgot to mention for i was to irritated working on it, but some more symptoms to help diagnose
• “Hood Open” light occasionally comes on
• “Rear Access Open” Light occasionally comes on
• Doors Lock and Unlock when hitting a bump, or driving
• ABS Light will flash at times, since the new harness has been installed it only comes on when scanner gets plugged in
• Traction control light on
• “Service Stabilitrac” is on the dash
Sounds to me like the BCM or underhood fuse block has gone bad.
Having said that, I would first hook up external power to the truck and then connect your scan tool and run diagnostics. I could be a bad battery after all.
B
Blancotahoe
Came out to the truck just now, battery showing 2v, jumped it off and going to run the tests
B
Blancotahoe
Update:
• Pulled all fuses, cleaned fuse block and connections
• Battery is completely shot, when another source of power was added the idle was smoother, check engine light took longer to come on (still cyl.1 & 6 had cyl 8 pop up for 2 missfires or so and went back to 0 instantly)
• CEL goes completely away at around 1.5 to 2k rpm, missfire data reads 0 on all cylinders when brought to said RPMs (with added power source)
my best guess besides the dead battery is you have a bad ground or short somewhere. I would start looking at the engine grounds for starters
B
Blancotahoe
What would cause my EVAP code, and my fuel pump relay to not get any power
"No Communication” on every Control Module (ECM, TCM, BCM)
Tells me there is likely a short, most likely in the lan bus, inspect everywhere you can see and look for a pinched or chewed wire, melted wires, wire rubbing on a surface and chaffing (common). lift everything you can that sits on something else and look for frayed wires
take a meter and check the lan bus ohm's on the obd port, I believe they should be 5 ohm's but just going off memory. testing that will tell you if there is a short or open circuit.
B
Blancotahoe
Where/ which prongs are the IAN bus
Getting 62 ohms car off and like 3 car on not sure how to properly diag with car on or off
Verify the high-speed LAN circuit integrity by measuring the resistance across DLC terminals 6 and 14 with a DVOM with the battery disconnected
if good then start pulling module fuses and re-testing communication after each fuse is removed
B
Blancotahoe
61 ohms battery disconnected
Notch
Had the same problem on my old 2007 Avalanache. The problem I had was the wiring loom shorted against the frame.
Sorry I don’t know exactly where since I had to tow it to a shop that found the problem.
But might be worth to take a look under truck at the wiring loom.
GMfan72
All grounds have been fixed
Hi - you mentioned 'all grounds have been fixed' I had a similar issue with 'hood open' etc coming on. I eventually had to replace the ground wires. There is a ground wire on the Battery that goes to the engine block and continues to frame on the battery side. There is another ground wire on the drivers side that grounds the under hood fuse box , etc on that side of the vehicle. You may need to actually replace the ground wires.
BadDaddy2003
