Rayyy
I’d like the dash cam to turn on automatically when I turn the key to ON, but would also like to be able to turn on the cam with the key out, using a rocker switched I installed.
My question is: could I tap into two different fuse locations in the fuse block, and wire them in tandem to the same power wire of the dash cam… so, if I turn the key, that fuse will power up the cam, otherwise if I hit the switch, the other (constantly powered) fuse will activate the dash cam?
Would it cause a problem to accidentally power on both simultaneously?
