2003 z71 tahoe
ncalvo
ncalvo
FL
Better hinges? I thought the only difference was the handle/rubber trim going around the glass.
I had thought the 2006 or similar years glass had hinges that were more secure.
I went to a junkyard with a friend a few years back and he grabbed one off an escalade.. Later he gave me his old glass that he had repaired the hinges on when mine broke.
I haven't see one in a while I thought they had an improved way the hinges attached to the glass I could be wrong
That's news to me, never heard that before.
ncalvo
ncalvo
FL
The junkyard near me has two 2006 tahoes and the inventory online shows the glass I want. One has been there a month the other 10 days I am gonna try my luck. Word is the 05/06 Glass doesn't have a history of failing hinges.. I will update if I'm successful
ncalvo
ncalvo
FL
I got lucky this morning and found the glass and it looks like it is in good condition. Missing one screw on the inside but I think its good to go, doesn't look scratched either. Man what a nice morning.
The hinges do look much better than the original.
ncalvo
ncalvo
FL
Cleaned up the glass, it is scratch free!
Broke a bolt when I tried taking the handle/strike plate off because I wanted to clean it up, it was very rusty. Not happy about that.
However I found what could be an identical replacement on ebay.
Also the new wheels are on!!!!!!!!!!!
ncalvo
ncalvo
FL
New duralast battery posts and Big 3 upgrade today. Overkill with 1/0 gauge but better than underkill. Also cleaned up the few grounding points that I know of.
New headlight housings, LED headlights/running lights/reverse lights, they are nice and BRIGHT. Kept the marker/blinker lights, highbeams, and foglights the same.
Getting ready to do the e-fan conversion, at the same time replacing a bunch of heater hoses and tee's, the surge tank, and the radiator.
After that the 2500hd conversion, cannot wait til these are done.
ncalvo
ncalvo
FL
Replaced heater hoses and tees yesterday, they were the original to the truck. Vice grips with a sawzall blade became my friend to get the old ones out. Also replaced coolant temp sensor, steam pipe gaskets up front, radiator, expansion tank. Then did the efan conversion, replaced the electrical box cover, got the new harness to fit in the OEM location but had to do some moving around there was a harness right there in that spot already.
Have to check trans fluid level after replacing the radiator but it shouldn't be much if it needs any added. When adding coolant I used the top hose going to the radiator to first fill the radiator, then attached it to the water pump and unhooked it to the radiator to fill more. Once I saw level in the expansion tank I buttoned it up and did the efan conversion. Then after I started it up put the heat on full blast and burped it for about 10-15min with the cap off, only had to add a little more coolant.
It did freak me out at first the fans didn't kick on but realized what they are programmed to kick on at and once she got to 184 they came on as expected.
ncalvo
ncalvo
FL
Below are my fan settings from a friend at SMG Motoring out of Massachusetts who did my tune
EDIT: I didn't know much about the fan settings before, but now looking at them my fans only respond to coolant temp, and not to my AC system since those settings are maxed. Until my truck warms up to 184 I don't get cold AC.
ncalvo
ncalvo
FL
Can't wait to do mine. I've only had the parts laying around 5-6 yrs lol.
Haha, let this be the motivation for you to knock it out!!
This morning when I went to start my truck I swear I heard a weird noise, then looking under the hood I saw steam or smoke coming out of the fans, they weren't on yet but I unplugged them and it was still coming out, probably coolant that I had spilled cooking off, I am not sure but it went away after a couple minutes, that wasn't fun but seems to be all good now, coolant level fine too.
ncalvo
ncalvo
FL
So the replacement part I bought on ebay for the hatch handle is an exact replacement, thankfully.
It is from an envoy/trailblazer from what I can tell by the listing.
Glass is in I am happy.
adventurenali92
Big Bear Lake, ca
Truck has come along nicely! You’ve done a ton of work too! Really impressive! You won’t be disappointed in the Michelin defenders! I’ve had them on just a little over a year now and they’re fantastic!
Rear hatch glass looks good too! The 05/06 style just looks better in my opinion! Glad you were able to get the sort to fix the handle!
ncalvo
ncalvo
FL
Replaced intake filter, cleaned the MAF (still original MAF may order a new delphi one this year)
Ordered a $25 Dorman door seal and used it on the back hatch glass.
The glass wasn't sitting firm enough, I could hear wind when driving and rattle when shutting.. now it is very firmly seated when shut.
Found a new spot to mount one of my big 3 grounds from my accessory bracket to the frame just need to get a nut and bolt.
Got a spare ecm off ebay for $60 sent it to get my fan settings fixed.
Every detail counts and each project checking off the list feels great to be done, very enjoyable to drive lately.
BadDaddy2003
