ncalvo
FL
It was. Is that where they come from- a GMT800? Is it a wear item, as in, would it be best to use a new one for a conversion? Otherwise, I might be interested in it and the pigtail, if you were so willing @ncalvo
I will keep you in mind, I have to find a local tuner to clear my code to make sure I am doing it right. I won't be able to remove the sensor until I get new fuel lines which won't be for a while. Sorry I don't have better news to send it your way but you're first on the list
I don't think it's a typical wear item, but we occasionally hear about someone having to replace one.
FYI my Tech 2 shows both the ethanol content in %, as well as a sensor frequency, IIRC.
This sounds vaguely familiar. I remember now that I read up on how it reads alcohol content. Obviously, I forgot what I read and that I even read about it.
As usual, I'm in no rush!
Still looking for an HD hood to do a Yukon conversion on. I found one fairly close, it’s even the right color so I wouldn’t have to paint the underside, but it’s got a dent right in the front edge. Anybody know if this is easily repairable from looking at it? I might have to ask my body guy. I’d have to cut the headlight areas out so there’s already going to be some body work on it.
srehmer
My Mountain Bike Carrier set up.
I'm brand new to the Yukon world. Just picked up at 2003 Yukon SLT with 240k mi. I'm coming from the 4Runner world, so it's a big size upgrade. Now, it's time to personalize. First up, figure out how to load my mountain bike. I haven't seen much of people carrying them inside, except for fully converted camping rigs. I need all 5 rear seats, so I wanted to do something that would set up and tear down easily. I set it on a track so I can load it on a side, instead on center, if I ever need more space. I think it will meet my versatile needs while remaining secure.
This was my plan:
Plywood
Kreg mini trak
Kuat Truck bed fork mount
Lynch Pins
This was my plan:
Plywood
Kreg mini trak
Lynch Pins
Looks great!
srehmer
My next project will be building in some drawers under the rear windows. I built a box drawer for my old 4Runner, which was an easy out thing, but lived mostly in the cargo space. However, the rear bench will be in enough that having a drawer in the cargo space doesn't make sense. Hopefully, having the side drawers over the wheel wells will give me the storage I want.
Sam Harris
I think that would be a a challenge for a lot of people, but the right body guy (or gal) should be able to handle that with ease. The ones who have the experience / know how, have some amazing talents. Good luck. I hope it works out! I want to see this on the Beast..!
Sam Harris
This was my plan:
Plywood
Kreg mini trak
Lynch Pins
Looks good. How about some pictures of your rig!? Welcome, from Texas!
If it's cheap enough, I'd grab it. Imo that wouldn't be a difficult repair. Like you said body work will need to be done anyway.
They want $300. I can’t even find a new aftermarket one, they’re out if stock unless I want to pay $800+. I’ve seen used ones in perfect shape on car-part going for $600+. I think I’ll ask my body guy what he thinks about it.
MassHoe04
Western MA
This was my plan:
Plywood
Kreg mini trak
Lynch Pins
Nice! You could also possibly use the slide-bolt side of a latch like this... So you don't have to track loose pins. It could stay attached to the board all the time and not get lost. Not criticizing anything in the design... Just brainstorming.
mwilson62000
Senior Member
Rear pads and rotors today. ACdelco Gold black hat rotors. They sent wrong pads, so went with local Napa pads. Forgot to snap a pic while the wheels were off, but you can see the shiny new rotor in the pic.
srehmer
That's a good idea. I could have use a lynch pin with a little cable attached, too. I didn't even think about how these loose pins could go missing.
blueinkd
Not the same body guy who laid the paint I hope
S33k3r
Dallas, Texas
Took my 2005 2500 Suburban to a mechanic on Monday. Trying to figure out why half my cluster has no power, the power mirrors/windows/door locks do not work, the lights on the dash don't work, and Quadrasteer doesn't work. Also, when plugging into the OBDII port, they get no signal. My regular mechanic started at the door switches which tested out good, but just couldn't figure it out (he is normally very good; he also didn't charge me for failure!). The new mechanic was recommended by a friend, and he only had a 10 day wait to get in; my mechanic's normal electrical guy had an 8 week wait. This is my wife's car and she is getting aggravated...
Anyway, if any of you have ever had an issue where the OBDII port wasn't working, feel free to share.
I can't remember if I ever gave the resolution to this or not... My regular mechanic was not able to figure it out; on the advice of a local friend, I took it to a guy that specializes in electrical wiring for cars. It took him 3 days, but he found the wiring coming into the ECM rusted through, with several broken, sometimes making contact. He went to a junk yard, cut out that portion of the harness, added it into my Suburban: Presto-chang-o, no more electrical demons. Also, wife now hapy again... ;-) This was back in December, and ended 2+ months of unreliability for our Suburban. Bonus: I now get to harass my wife about driving through high water in the Suburban (it was only up to the wheel wells...)
BadDaddy2003
