Help with GM kicker sub
Danyi2170
San Diego
So I got this installed and everything works good. ( factory Bose system) Problem is every few minutes or longer the sub starts rumbling for a few secs. It starts off low then louder. Dealer disabled active noise cancellation. And it happens whether the music is on or off. Any ideas?
Does it happen when the motor is off, as well?
Danyi2170
Danyi2170
San Diego
No only when car is on. Also I noticed today when the noise appears and I step on the gas the sound goes up and down with the gas pedal. Almost as if the exhaust is coming through the subs. Again it last for an only few seconds then back to normal.
K2 Kaiju
The Depths
Been doing a lot of research on this the last few days before my sub install. The 10 speaker Centerpoint Bose system in upper trims has the Audiopilot feature that compensates for road noise when listening to music. Certain GM vehicles also have Bose Active Sound Management which uses the audio system to offset or enhance noise - Engine Harmonic Cancellation or Engine Harmonic Enhancement. Finally Bose has Quietcomfort Road Noise Control or RNC. This is newer version of ASM.
All of these systems rely on a series of microphones in the cabin to hear and send signals to offset noise with speakers. I believe the newer 18+ vehicles with the Centerpoint ONLY have the Audiopilot feature that can be turned off in the head unit settings. I speculate that the ASM was in the earlier models, but was removed due to the famous "buffeting" problem, but I dont know for sure. Long story short - turn off AP in settings; if that doesn't work, disable the mics. I have seen a harness on YT that does this at the rear Bose amp, and I have seen people just pulling the mics and cutting the wires. The mics are in the 3rd plug down, so maybe you can pull it first to try it out.
As a final note - 9 speaker Bose like mine in the LT do not have Audiopilot...
Danyi2170
Danyi2170
San Diego
When there is throttle related feedback, usually a ground wire is the issue.
That’s what I’m thinking
I had the dealer disable the active noise cancellation. I think it might be a ground issue. I’m not having any distortion or feedback issues when playing music. Just randomly my exhaust (aftermarket) sound will come through the subwoofer at low speeds when braking for a few seconds then disappears.
Danyi2170
Danyi2170
San Diego
Update. I turned off AudioPilot But my exhaust still comes through. Dealers gonna take a look at it tomorrow.
Danyi2170
Danyi2170
San Diego
Another update. Brought the car to the dealer and they told me this is normal. Haha. What a joke. Anyways , I read on other forums that cutting the Crankshaft Position Sensor Replicated Signal wire is the solution. Anyone ever try or heard of this? I’m gonna take it to a car audio place and see what they say. They can’t do anything I’m gonna take this sub out.
Roll On
Another update. Brought the car to the dealer and they told me this is normal. Haha. What a joke. Anyways , I read on other forums that cutting the Crankshaft Position Sensor Replicated Signal wire is the solution. Anyone ever try or heard of this? I’m gonna take us to car audio one to dollar and see what they say. They can’t do anything I’m gonna take this sub out.
I would tend to think that the speaker is fine, just something with the program in the sound system is acting up. Bad grounds are good start.
I would recommend a different dealership or buying a service manual and reading through it, a lot of information on the troubleshooting process in there.
Danyi2170
Danyi2170
San Diego
I would tend to think that the speaker is fine, just something with the program in the sound system is acting up. Bad grounds are good stI would recommend a different dealership or buying a service manual and reading through it, a lot of information on the troubleshooting process in there.
The speaker is fine. Music plays nicely. Supposedly the dealer turned off the active noise control. I was thinking of picking up one of those active noise control disablers first because it’s like $15.00. Then if that doesn’t work an actual car audio place that can hopefully diagnose the random feedback.
Roll On
I am not so sure about cutting crankshaft position sensor wire.
For the limited knowledge I have, that actually works as a distributor for the engine to fire.
I believe that is very bad advice.
Danyi2170
Danyi2170
San Diego
Yeah I agree that’s why I’m gonna try out that bypass harness so I don’t have to do any hacking.
Danyi2170
Danyi2170
San Diego
I meant cutting from the bose connector. It’s part of the ANC system. If you look at the schematic you will see all the mics and other things associated with the active noise cancellation. Anyhow I’m not cutting anything lol
Danyi2170
Danyi2170
San Diego
UPDATE. finally got rid of it. The ANC bypass harness was all it took. Take in mind these harnesses are hand made when ordered so it will take a few days or so depending on number of orders ahead of you. $19 after taxes solved my headache.
kskcheche
Cutting that purple wire does the same thing. And basically the dealer did not disable ANC if that harness fixed it. Hope you didn't pay them anything or else I would be asking for my money back.
Danyi2170
Danyi2170
San Diego
Cutting that purple wire does the same thing. And basically the dealer did not diable ANC if that harness fixed it. Hope you didn't pay them anything or else I would be asking for my money back.
Yeah, I figured they didn’t do it correctly because they said they did. To actually disable the ANC, the dealer has to call TCSC to have the calibration changed. Then they have to install it using their scan tool. I’m sure something went wrong during the process. But they did install the subwoofer so no use in asking for a refund. Just going remind them the tech who did it didn’t do it right.
BadDaddy2003
