2021 Denali - Vehicle Knock, Stutters, Surges, Rough Acceleration - In Auto Mode, After Lifting Rods Replaced
jepaul2198
Hello,
Apologies ahead of time for my first post being what it is. I'll try hard for brevity, but often my posts are long because I do not have time to make them short.
I'm not a mechanic and can barely change al alternator on a 1993 K5 Blazer, I'll do the best I can.
2021 Yukon Denali
Currently 21,000 Miles
The problem first started at 16,000 miles (August 2022)
Magnetic ride and air suspension
Current Issue: After replacing the lifting rods and cam actuator, the vehicle does not drive right in AUTO mode. Prior to lifting rods being replaced when driven in AUTO mode, the car accelerated smoothly with only a hint of the gears changing. It was smooth at slow or fast acceleration. After the lifting rods were replaced, acceleration is bumpy, rough, and hard when set to AUTO mode. It almost feels like it is shifting ten micro shifts in between each real shift. Some of the "bumps" or "feeling" is hard, like pushing a manual speed into gear. But again, none of this is actually gears changing. It feels like it is surging or stuttering between each gear. It is faint, although some are harder than others and indeed hard enough to feel, and it is continuous. At higher speeds, it's almost like going over micro rumble strips, or the tires are out of balance.
After replacing the lifting rods, I took the vehicle to two dealers. When first bringing the car to them, each dealer test-drove the vehicle in AUTO mode and agreed something was wrong. Only after they have had a chance to look at it will they come back and tell me to drive it in 2WD mode. But there was never a problem in AUTO mode before the lifting rods were replaced.
I have also test-driven other 2021 Denalis, even going so far as to rent one, and drove them around to be sure I wasn't imaging things or being a weird OCD-type customer. There is something wrong that wasn't wrong before the lifting rod repair. I feel like the dealers agree there is something wrong when they first drive the vehicle, but when they can't find any codes or warning lights, they don't know what to do, so they come back and tell me, "GMC says to drive it in 2WD mode". But that isn't the point. It never had these issues before the lifting rods were replaced.
Snap Shot – High-level points over a 6-month period and many visits and calls left out. Total drives to different dealers is 9. The total spent on rentals is $2350. Total time so far +6 months.
The vehicle never had any of these problems before the lifting rods were replaced back in August. Only after that service did these problems in AUTO mode start.
Chad G 1979
When you say AUTO mode, are you talking about the transfer case being set to auto and not 2 high or 4 high? Is there a reason you drive in auto all the time instead of 2 high? From what i have read in the owners manual, auto is supposed to be used when road conditions are variable, say from dry, to snow covered and back, but not necessarily to be used all the time. If you need auto used all the time, then its needed, but i belive it has the transfer case running in a configuration that makes it quicker to change from 2wd to 4wd vs standard 2wd and may be causing some excessive wearor something is damanged in there. Just my thoughts on it.
J
jepaul2198
Thanks for the reply Chad.
Yes, I'm referring to the setting of AUTO versus 2wd or 4wH. I understand the point you are making with the manual, its the same point the dealer is telling me. But my point is there was never this issue in AUTO mode prior to them replacing the lifting rods. It ran silky in AUTO prior to that work. My wife doesn't want to have to think about putting the car in 4wd or auto when it might start raining or be a little slick in the mornings when she backs out. She wants it just like the land rover we had where she sets it to AUTO and the car decides what it needs to do, not her. (I want the car doing this also and not her) As far as GMC is concerned lets just assume my road conditions are always variable so I need to always drive in AUTO. I would like the car to drive the same way in AUTO as it did before the lifting rods were replaced.
Thanks for the verbiage on transfer case and wear/damage. Gives me some talking points.
Blackcar
Why where Lifting rods replaced and clarify what a lifting rod is.
J
jepaul2198
Lifting rod(s) broke on August 8th. I got the vehicle back on August 22nd.
This happened - https://www.tsbsearch.com/Chevrolet/PIP5776C - In my case a rod broke and the vehicle was not driveable. Specifically I was turning into a starbucks parking lot and BAM something happens and a loud knocking starts and the vehicle limps from there.
And this update to the above PIP - chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://gm-techlink.com/wp-content/uploads/2022/05/TAC-Dealer-Monthly-Tips-and-New-Information-May-2022v3.pdf
And then this was done - https://www.tsbsearch.com/GMC/PIP5794B
Important to still note the current issue was not happening before the lifting rods issue. PIP5794 was an attempt by the dealer to fix the current issue but it did not fix it, so now they say just drive it in 2WD.
Stbentoak
Does the vehicle exhibit the same problems in 2wd? If not, at least your problem is isolated to the drivetrain. If so, it could be a tranny software issue. It should be driven with a monitor hooked up to is to see what the output of the engine and tranny are under load. Who knows what got changed when you were in for this "Lifting rod" issue...
While technically you "can" drive it in auto all the time and nothing should stop you from doing that, it's really pointless and has no benefit ( And possibly some negatives..) Unless your weather conditions truly dictate this... backing out of the driveway or a little rain doesn't dictate Auto. I've drove mine thru blinding rains in 2wd and I'm more concerned about hydroplaning on crappy stock tires than wheel slip on interstates. This vehicle is pretty heavy, and in 2 years of 4 season driving, I've probably had in in auto 2-3 times max.
J
jepaul2198
Thanks for your reply ST. It does not have these same symptoms in 2WD.
Of course you are correct that manually switching from 2WD based on conditions is optimal, a smarter man than me can have that conversation with my wife. Who just wants to set it and forget it just like her lovely little Discovery did that I fought to trade in for this because I wanted more room. "We never had to think about when to switch things in the Land Rover", Wife
I just want the vehicle to drive like it did before the liftin rod issue. Regardless of if/when I shoudl have it in 2WD my point with GMC is that the vehicle drove great before, so I would like it to drive like that again. It happened at 16,000 miles, full warranty.
Stbentoak
Then it sounds more like a front driveline/transfer case issue. A savvy dealer should be able to isolate that and/or detect a problem….
Blackcar
I would go to different dealer engine should operate same in 2wd as in auto, which is transfer case and not engine operation now in 4-wheel low it will cause transmission to operate differently.
Z15
Michigan ,USA
What are lifting rods you are referring to??? Or do you mean pushrods inside the engine?
J
jepaul2198
I'm 0 for 2 thus far on that. The frustrating part so far is each dealer, when I bring it in, had test driven it first with me so I can confirm they agree there is a problem. Each has agreed there is a problem until they go back to take a look at it and say they can't find anything wrong with it and GMC says to drive it in 2WD anyway.
WalleyeMikeIII
Sunny and Snowy Minnesota
If you had the well known lifter/collapsed lifter issue, that issue is resolved by removing the heads, inspecting and repairing as needed the valve train, the pushrods, and the lifters; as well as the cam; if needed.
Sounds like that was accomplished -- that is an engine issue.
If that issue were still happening; you would notice it in idle (Transmission in park or neutral) and while driving (transmission in Drive or Reverse or any of the manual forward gears).
You describe an issue that only manifests itself when you have the transfer case set to "Auto" and you are moving.
Thus, the conclusion is you have a driveline issue.
What you don't mention is whether you have a 2 speed transfer case or a single speed (ie, do you have 2High, Auto, 4High, and 4Lo, or do you only have 2High, Auto and 4 High?)
Regardless...if you can demo this issue to a competent service advisor/tech, and demo that it goes away when in 2High, then that same competent service tech should be able to diagnose.
Your powertrain (engine, transmission, transfer case) are covered under the powertrain warranty to 5yrs, 60k miles...so rest easy.
I can tell you, I have a Denali w/ the 2 speed transfer case, and I can hardly detect a difference in the vehicle between being in 2 High and Auto...and given the winter we have had, I have had it in Auto quite a bit. It's smooth as butter.
For some more details on how this transfer case works, suggest doing a little google search for GM Autotrak transfer case. Here is one article.
Net, you need to find a dealer who is willing to listen; tell them to drive a pickup or full size SUV from the lot and see if it does the same thing...it should not.
You could have issue w/ CV Joint, TransferCase, Hubs, Transmission (although I doubt it, since it doesn't do it in 2WD), Front Drive Axle, etc...
Stick to your guns, regardless of whether they say you should or should not be driving in Auto, the vehicle in Auto does not tend to bind up, make noises, etc.
If you put it in 4hi, and drive on dry pavement, you could get some of what you are saying <--- don't do this.
Pro299
OK, now that we understand you were referring to the well known lifter repair (which in your case included at least one bent push rod), we have a real head scratcher. That repair is a "top of the engine" procedure and normally one would not expect that to have any impact on 2/4WD operation. Hard to imagine how the repair and your symptoms could be related. It could be coincidental, or maybe a wire harness or connector got pinched, control module communication was compromised or some other incidental component was accidently hosed during the repair. Unlikely, but stuff happens. I would back off insisting that the repair caused a problem and just treat it like a separate issue. It may take a really good tech to diagnose and I know those are getting hard to find. Good luck.
J
jepaul2198
Thanks Pro. I appreciate the guidance. Note just 6 days ago a separate post was made with almost identical issues from. Cdip01 - https://www.tahoeyukonforum.com/threads/4wd-auto-problem.139109/
I got the message from the dealer yesterday saying they performed all the recal work and my car is ready. That I should drive it in 2WD as GMC recommends. I pushed back hard asking them to please drive it around the block a few times and then drive one on the lot around. The differences will be impossible to miss. I think, simply my opinion, is the dealer(s) don't know what to do if there are no warning lights, codes, or easy fix that pops up when they search their internal help menu. Because my problem is not so bad that it is loud or severely impacts performance it is easy for them to just say that is how it is in AUTO. But dangit it isn't, as someone else mentioned it should drive and feel approximately the same whether it is in AUTO or 2WD.
J
jepaul2198
What you don't mention is whether you have a 2 speed transfer case or a single speed (ie, do you have, 4High, and 2High, Auto4Lo, or do you only have 2High, Auto and 4 High?)
Thank you very much for the detailed response. Note: I have 2 speed transfer case, 2WD, 4WD, Auto, 4 Lo. You've given me some great talking point and they are much appreciated.
Its worth nothing a separate post was made 6 days ago with almost identical issues. https://www.tahoeyukonforum.com/threads/4wd-auto-problem.139109/
R32driver
Having owned a 2011 suburban for 8 years and now our '21 yukon for 1.5 years I can say for sure these vehicles do not drive the same in AUTO as they do in 2WD. There is a noticeable difference in feel and noise level when these are in AUTO, its like more rolling resistance and some added drivetrain noise. It's not major but the difference is definitely there. 2wd is super smooth always, AUTO is not. I'm not saying yours doesn't have a weird issue going on but in AUTO mode it will never drive the same as it does in 2wd.
DuraYuk
I don't think you understand what AUTO does. If you are driving in Auto on dry roads just for the hell of it you are prematurely wearing things out. The reason it was smooth before and not now is because you wore some things out a little.
You just noticed after the repair. But the repair should have nothing to do with what your feeling.
When I worked as a heavy line tech for GM we saw many driveline issues from people driving on dry pavement with it set to AUTO.
The owners manual specifies when it should be used and dry conditions isn't one of them.
Good luck.
mb1500
Find a long stretch of straight road and switch to 4wdHI and see if the issue is still there. Make sure to go back to 2wd or AUTO before making any sort of turn if you’re on dry pavement.
B-train
Agreed. In all the GM vehicles I've had with the AUTO option, there was/is more drivetrain noise as well as more rolling resistance.
AUTO locks the front dif into 4wd mode and allows the front and rear tires to rotate differently than each other until a threshold of slip is detected. Then the clutches in the TC engage the front driveshaft and send power to the front wheels.
There is no need to use AUTO unless you have a mix of slippery surfaces to traverse. With the stabilitrac system, 2wd will get you just about anywhere without a spin out. Traction control on the other hand is a completely useless feature that will get you stuck more often than not. I would suggest to the OP on familiarizing oneself with the traction control/stabilitrac disable feature should you need actual wheel speed/spin to get put of a stuck situation.
I always laugh when I see a newer 4wd or AWD vehicle in the ditch and the driver waiting for a tow when they could easily press the GO pedal with the idiot monitor turned off and get on with their day. Keep the tires spinning and they will clean themselves and look for new stuff to grip.
varminpoolteam
