Tonyv__
Bucks county PA
Comparing rear bars-
Mostly same shape with slightly more clearance where it matters:
Factory bar is 28mm, hollow and 9.8 lbs.
Nolathane bar is 33mm, solid and 24.2 lbs.
End link holes are right at 1/2" closer to the axle. I had the bars centered with each other at the axle mounting points. Also, the holes were more true to size- the 1/2" bolts had noticeably less slack than in the factory bar:
The Nolathane axle mount bushings have thicker bases, so bolting up that offset axle bushing was a struggle. I couldn't finish because I need longer bolts for the end links. With the original bar, the bolts would be flush with the nuts when tightened. I'd be lucky to get half a nut threaded with how thick the ends of the new bar are:
I have to wonder what the difference between this sway bar and the hellwig bar is.
the hellwig says it fits 2015+ but the brand your using says it doesn’t. They look damn near the same but obviously I’m not comparing them in person
Edit
Actually if I just did a minute of research I wouldn’t have to ask this.
Rockauto list the same part number for rear sway bar on 2008 as it does for 2015. So assuming they’re the same shape still confused why the websites fitment says it won’t fit 2015
Even if i go to nolathanes website. They only offer the front sway bar when I input 2015 Yukon
Edit
A lot of manufacturers and retail sites don't bother updating fitment info beyond a certain age. The body style changed for 2015, so they might assume the undercarriage might have changes as well. It's why a lot of sites say a drop spring fits '00-'14 when, in actuality, it'll fit up to '20. It's probably more of a CYA thing. They're not necessarily saying it won't fit or work, but they can't guarantee that it will and it's not worth their time to investigate. But, for an individual's firsthand experience in seeing this particular area is the same across the generations, we'd know better. How often do you see Amazon's fitment guide saying "This does not fit 2015 GMC Yukon" for items many other people have bought specifically for this vehicle?
Size- and material-wise, the Nolathane appears to be functianally the same as Hellwig with the exception of the color and rear bar. The Hellwig rear bar has three holes to adjust firmness and includes adjustable end links. The Nolathane bar is advertised as being 1mm thicker, which I'd say is totally negligible. Being lowered and needing offset links, the adjustable Hellwig links would be a waste for me. For suiting me better and costing a few hundred less, I'm plenty satisfied with the Nolathane.
I bought them as a front and rear kit off Amazon, Nolathane part #REV013.0030. I documented each bar's part number here: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1735470. If all you want is the rear, you might be able to find it by that number. Or just do yourself a favor and upgrade both. :thumbsup: There's still one kit left on Amazon cuz @pwtr02ss hasn't bought it yet. https://www.amazon.com/Nolathane-REV013-0030-Swaybar-Suspension-Stabilizer/dp/B07VFD1QDM
Tonyv__
Bucks county PA
I only questioned the rear because it didn’t show fitment. But the front says it’ll fit. I’m considering them since I also don’t want to spend hellwig money
That's kinda odd. I looked up images of the rear suspension of a 2015 and it looked essentially identical. AFAIK, it'll work fine.
SpineDock
Clearwater
Replaced the stock 80-lb. trash can of a muffler with an AP Exhaust XS1259.
Made some comparison vids. Slow rev to limiter (4,000 RPM, I think) then a few WOT blasts to limiter.
Before:
After:
Honestly, it's much less aggressive than what I wanted. With the muffler being about a 1/4 the size of the stock one and almost straight through, I expected it to be louder. My best description is that it's basically the stock note/tone, but with the volume turned up one or two clicks. Comparing the videos, the XS actually sounds quieter. It's definitely louder, but deeper. Very smooth and mellow. Maybe the camera recorded the sound differently? The sound it gives off seems to cancel out the growl from the MIT. When cruising, it sounds almost 100% stock and you can barely hear a deep rumble coming from behind you. It's definitely noticeable when you mash on it, but it's still not as aggressive as I was hoping for. I'm gonna run it and see if it changes it's tone with age. It may end up being perfect after the packing gets a little clogged and with catless long tubes. If not, I can easily switch to a chambered style like that Jones one @kbuskill has.
Thanks for the info! I am leaning towards some form of modification to my 2015 Tahoe’s stock exhaust.
My question is: did you have any drone sound to worry about when cruising @ 2,000 rpm’s? How about a drone noise with just the resonator?
No cruising drone at all with it. There are instances where the engine noises are louder when under load. It's not necessarily RPM dependent. It's more of intake sound from the MIT and it's only when under load, like when going up an incline and it's not quite enough to downshift. Totally normal and, even then, not so loud. Again, it's mostly from the intake tube. If you have a stock intake, it'll be almost stock volume until you're at hard throttle and high RPM.
BTW, Cherry Bomb now has their version of these mufflers and they're a little cheaper. Look up the "Salute" line. The Cherry Bomb copy of the AP Xlerator I have (#XS1259) is #SA1259.
I assume you mean with just the resonator delete. I couldn't tell any difference with just the resonator gone. It might be for certain frequencies created at certain RPM or maybe even for some created only when AFM is active.
Caddylack
Even aside from the resonator, our exhaust is constructed nicely for "natural" resonation.
As far as maximizing scavenging and minimizing drone, you generally want the exhaust to get smaller from front to back. We have a nice big Y-pipe that goes into a decent 2.75" mid-pipe. Then the axle-back portion gets smaller in diameter and you have the resonator on the tailpipe.
One notable exception to the "front-to-back" concept is mufflers, as some folks like to go with a muffler that has an inlet/outlet that is slightly larger than the pipe.
Here's a question: What's up with the factory flex pipe? Can I ditch it?
Yup- goes from 2.75" ahead of the muffler to 2.5" after. There aren't many 2.75" options for aftermarket mufflers so the more common 3" is used. I slid the factory 2.75" inside the 3" muffler inlet and only had a very small gap to weld up. I wanted to keep the size reduction after the muffler so I made a tapered elbow to smoothly transition from the muffler's 3" outlet to the 2.5" tailpipe.
You can ditch the factory one if you want. But I'd suggest you replace it with another, even if it's aftermarket. The engine twisting in its mounts and all that piping downstream of the flex joint moves independently. It would produce a lot of leverage against the weld seams and rigid coupling points if there wasn't a flexible coupling to isolate the movement.
Caddylack
Is there anything unique about our platform relative to other platforms that don't have a flex pipe?
If I don't need a flex pipe on a Roadmaster wagon, why do I need one on a Tahoe?
Maybe the Roadmaster had better engine mounts than the water balloons we have? :rofl:
Maybe it's a torquing thing- higher power and a heavier vehicle? Also, doesn't the Roadmaster have dual exhaust?
Caddylack
Better engine mounts... probably.
Higher power; no. For one, a 94-96 Roadmaster wagon has the same amount of torque as a 2007-2014 Tahoe. The Tahoe has a few more HP in stock form, but there are some brutally fast wagons out there, and flex pipes have always been considered a "ghetto" or "temporary" repair on those cars.
Heavier, yes, although obviously this would depend on the usage of the vehicle as far as passengers, towing, etc. Remember the Roadmaster has 8 seats, including the 2 rear-facing seats in the tailgate area. Your kids will see it coming when you get rear-ended, but you won't. It also tows 7k lbs from the factory.
Dual exhaust... Bingo. After thinking about it, it's because we have a big Y-pipe. So, when the engine shifts back and forth, left and right, you have this solid Y-pipe transferring all of that torque to one pipe. With a true dual exhaust setup like the B-body has, you greatly reduce that stress by allowing each side to move independently.
I will leave mine for now, since it doesn't leak (yet).
I had no idea the Roadmaster was so heavy or even had similar enough torque as the Tahoe. I imagined the Tahoe was heavier and had more torque and was capable of towing a lot more. This, coupled with squishy mounts, would allow the engine to twist a lot more, especially when towing. Anyway, that's pretty cool about the Roadmaster's strength.
Undercover family hotrod.
Caddylack
A B-body wagon weighs about 4500 lbs and has a fully boxed frame. They all got the LT1 from the F/Y-bodies, with 260 horse and 330-335 torque.
The sedans weigh about 4200, with the exception of the Fleetwood, which has an extended wheelbase and weighs closer to the wagon's 4500.
They were the last muscle cars that GM ever built (unibody = no muscle car). The chassis was virtually unchanged from 1977-1996, and really it dates back to the mid-70s Monte Carlo platform and the A-body platform before that.
Undercover family hot rods for sure.
Interestingly, those heavy whales are actually lighter than modern cars. Look up a Charger or CTS-V or something, and you will be shocked. All the electronics and safety crap adds up quick. The Charger even has a longer wheelbase.
That's not even that bad on weight. They probably just feel heavy from the comfy suspension. I love the sleeper aspect.
Caddylack
Yeah, the wagons had air suspension in the back for towing, and never came with a rear sway bar, strangely.
Drive a police package Caprice or the almighty Impala SS, and you will "get it" as far as those cars are concerned.
While I'm at it: That platform is heaven for an LS swap. They used the 4L60E, so it's just a matter of changing the motor mounts and the wiring harness. The engine bay is huge, so feel free to stuff abuncha turbos in there.
I'll try to not keep carrying on about this... :)
I've already pictured a "ŵoody" wagon, kept original-looking, mild drop, widened stock rear wheels, performance suspension, steering and brakes and a turbo'ed LS under the hood.
Caddylack
I've already pictured a "ŵoody" wagon, kept original-looking, mild drop, widened stock rear wheels, performance suspension, steering, and brakes and a turbo'ed LS under the hood.
Oh... Kinda like mine? Excuse the stance, I was running (free) front tires that were actually a full inch taller than the 275s in the rear.
And then at the end of the day, mine does something that the Impalas can't do:
One of my local friends has a Duramax and 6L90E in his Roadmaster wagon.
Cool AF! Do you have optispark issues with it? I've read it's a common issue with the LT1 motors. I've always liked the look of the SS rims on the wagons.
pwtr02ss
Tennessee
I used to want one of those. Black with woodgrain. Cool cars!
ScottS-Michigan
