thinking of buying an 09 yukon xl
Geotrash
Dave
Richmond, VA
Ok I’ll have to mess around for the video then. And as for the engine I asked the salesman I’ve been talking to and he said the engine did not meet their standards and they were replacing it with a new engine. I assumed it was for a lifter issue but I don’t know exactly what the reason was. And the carfax had regular maintenance done. And they were going to do a factory gm crate motor but it’s ok national backorder so they are putting in a jasper engine so I’m assuming (again) it’s a remain’d engine but has a 3yr/100k warranty
Jasper engines are hit and miss but they're probably the largest national rebuilder, and having a warranty on it is a plus. I'd personally be fine with that.
If there is any way to negotiate with them and have them put a new torque converter behind that engine in exchange for some more money up front, it would prevent the biggest reason why the 6L80 transmission fails in these. You'd be good as new at that point.
C
Chughart
Well they’re putting a new torque converter in and replacing the rear shocks so it’s going to have 3 of the major components replaced and everything else checked. Supposedly the engine was finished yesterday and they’re putting the shocks on on Tuesday (they’re closed on Monday) so it should be ready to pick up Wednesday. I’ll post pictures and update whenever I go get it!
petethepug
Michael
SoCal
Oh my goodness Chug! That dealer rocks. Apparently they’re taking care of the friendly neighborhood Honda dealer.
Start shopping for range disablers to turn off the AFM and you’re all set. Dual DVD screens. I’m pretty sure I see ventilated front seats up front. It also looks like you got the HDD version of the Navi that has a built in hard drive for music & better memory based Navi unit.
If it is the HDD unit you can add a $69 A2DP accessory that allows music & audio steaming integrated in with the existing BT for phone controlled by the steering wheel. 5 minute install behind the glovebox. The only weak spot is the headlamps. Consider warming them up, removing the lens and implanting a modem HID or LED projector lens set up. Aftermarket replacement units still underperform.
Is that DWT / diamond white tricoat paint? If so, no clear coat peeling for you. It appears as though you got a debadged Escalade. Nice find and njoy the nap wagon.
C
Chughart
Ya she’s really nice! I got her yesterday and drove it 3 hours back home. They replaced the engine, torque converter, rear shocks and compressor, oil and trans cooler lines, plugs and wires, and rear brake pads and rotors. It’s pretty much a rebuilt Yukon at this point lol and I’ll have to check out the Navi some more I haven’t really messed with it too much
Will definitely have to check some threads on the forum to see what all I can get into lol I’ll post more in depth pictures tomorrow
petethepug
Michael
SoCal
I just ran into a cure for the weak headlamps as well as an upgrade. I can’t believe no one has these yet.
* Plug n play harness
* 5 year warr
* LED running lamp bar
* Bi LED morimoto headlamp
* DOT legal so no blinding oncoming traffic.
These are especially good for black trucks. The OEM headlamps are so weak that dark colored Yukon are almost invisible.
B-train
Glad it finally worked out for you. It sounds like you found a stand-up dealership. Enjoy the pretty ride, looks good!
Wing Bucket
Looks great Chughart! Sounds like a good find.
@petethepug Can you tell us how to confirm whether the navigation is the HDD version? I’d like to check mine out too as it looks similar. Music and audio streaming would be great to add.
Miami-Dade
Moderator Supporting Member
You did extremely well getting your Yukon at this dealer! I am sure their service is excellent as well.
Please post the name of this awesome dealer as other members here [including myself] might want to check that dealer out when in need of a vehicle for themself or a member of their family. I am sure other members here drive though Virginia [I do several times a year] to get to their final destination on a road trips.
Thank you!
Geotrash
Dave
Richmond, VA
Please post the name of this awesome dealer as other members here [including myself] might want to check that dealer out when in need of a vehicle for themself or a member of their family. I am sure other members here drive though Virginia [I do several times a year] to get to their final destination on a road trip.
Thank you!
+1! I *live* in Virginia and would do business with them for sure!
C
Chughart
It was Rick Hendricks city Chevrolet in Charlotte North Carolina! They were awesome and very patient as I asked a ton of questions and was borderline a pain in the ass lol.
I did find an oil leak that appears to be coming from the plug (oil temp sensor location???) that’s on the passenger side of the oil pan about half way up. Going to pull it and seal it up and see if the leak goes away. Put it on the lift at work and checked everything and sprayed it off and added oil dye to check with a uv light to see where it’s coming from.
I also went to open the rear glass and one of the defrost contacts came off the defrost grid so if anyone has any solution for that that would be great lol
As for the headlights, those things are nice but a bit pricey. I had a set of LED headlight bulbs in my Tahoe that made a night and day different when driving at night. I may buy another pair of those to brighten the night driving a little
C
Chughart
Also does anyone have pictures of the Escalade tail lights installed on these? I’m contemplating replacing the tail lights but I’m not sure if I’m going to.
Frost Fighter comes highly recommended by many members: https://frostfighter.com/
petethepug
Michael
SoCal
There’s the glue repair kits or simply solder them back on. I’d do solder.
While the pan is off replace the 99¢ Oil pump o ring that fails and starves the motor at the worst possible time.
The HDD Navi w/ 30 GB hard drive for music storage pauses live radio and has its XM tuner separate and behind the glove box door. Only the HDD & Escalade Navi accept the $69 A2DP music BT module. Bummer they just raised the price to $104
Expect to pay about $150 for 3 yr weather & XM live traffic report announcements. Unlimited XM best price is $99 for 3 years (after your free trial).
Line in for iPod/ music and storage screen.
The back up grid lines on the 11/12-14 HDD Navi units.
Did the truck come with vented front seats!
C
Chughart
that video was very helpful! thanks man! will definitely be doing that in the near future. as for the oil leak i found that plug i was talking about in the side of the oil pan wasnt tightened. put a 17 on it and cranked her down and no more leak. and looking at your pictures of the hdd navi unit im pretty sure that is the same unit that is in mine so will definitely be doing that interface module you were talking about. and as for the seats yes it is heated and cooled seats which is awesome!
im thoroughly enjoying this thing. only issue is putting premium in it at 4.19 a gallon hurts lol but its the price you pay for something so nice lol
Hodmjstone
