992dr
Wow, they look great. Where'd yah find them and the replacement door cards?Picked up the seats and got them installed today - i *swear* they've never been sat in before. very happy about it
I'm actually taking them off - they were part of the "detainee" section, including the "you can't get out of the window" acrylic bits that are removed in this imageWow, they look great. Where'd yah find them and the replacement door cards?
Sorry, I meant where did you get your new door inserts and rear seat?I'm actually taking them off - they were part of the "detainee" section, including the "you can't get out of the window" acrylic bits that are removed in this image
was gonna take a pic of them for @Sparksalot likely tomorrow or Monday.
they're not super fancy, even tho they do look pretty clean (other than how they are attached to the frame). the have some little module on the rear door window wires (it appears the front buttons to manage the rear windows don't work if they're not hooked up).
I'm not going to have a use for them when i get the door panels inserted
ebay for the new inserts (120 each)Sorry, I meant where did you get your new door inserts and rear seat?
Thanks
@SparksalotI'm actually taking them off - they were part of the "detainee" section, including the "you can't get out of the window" acrylic bits that are removed in this image
Seems like FB Marketplace is quickly replacing Craigslist. I would love to get a leather bench seat to replace the vinyl one I got in the SSV. Everything on CL is trashed, overly expensive, just doesnt exist. I looked at car-parts.com too to look at salvage yards - them fools think the frames are made of gold! The search continues! lolebay for the new inserts (120 each)
also ebay for the rear seat (400), but was local pickup! by pure luck
3rd row seats likely tomorrow from Facebook MarketPlace (200)
console should be here tuesday (ebay - and a bit spendy imo @ ~450 w/ shipping)
I had that same horn issue on theothertwin. A 5 second fix after 2 weeks of YouTube university.Jan 12, 2023:
- fixed the broken airbag sensor connector from driver seat; service airbag warning is back off!
- got rear door speakers in
- got the rear door panels in finally now the speakers are in
-- one of the window switches doesn't work, and the other is 50/50 on going up
--- like $20 replacements from ebay on the way
- got the horn working
-- this was an interesting fix, found some youtube videos about a severed tan wire, it wasn't severed, but there were 2 tan wires --- disconnected them both and connected the ones *from* under the dash together, boom insta-horn working
- still need to do the parking brake, appears to be just adjustment needed on this
Priorities
1. getting MD state inspection passed
2. registered
3. 3rd row finally installed
4. intstall stinger and get 2nd battery sorted out (need to remove a bunch of non-switch aux wires just danging)
5. new head unit
6. hitch? new rear bumper? aftermarket? dunno yet
If you do a hitch, go ahead a replace the rear impact bar to get a factory hitch. Also get the GM 7 pin socket for it. The pigtail to plug into is just behind the bumper with a cap on it.Jan 12, 2023:
Priorities
2. registered
5. new head unit
so adjusting the parking brake didn't get me anywhere, without pulling the wheels I'm just assuming there are no shoes - or some other adjustment is needed that I don't know about --- I have a tech coming out to look at it on monday and replacing shoes/adjusting itJan 12, 2023:
Priorities
2. registered
5. new head unit
Didja pass though?good news!
got the parking brake shoes replaced and parking brake adjusted
took for MD state inspection
3rd brake light is out (it was working, and i think i know why it isn't now)
1 bulb out on the license plate (ez fix)
bright headlights don't work --- this one i'm not so sure about cause of the various potential causes i've read on these, maybe try and look into tomorrow.
then i need rear shocks - need to see if this is something i can do myself, or take somewhere/pay.
i can't wait to drive this damn thing![]()
nahDidja pass though?
The rear, and standard PPV?nah
two of the lights is gonna be ez fix
the headlight situation im going to have to figure out
i can't seem to find what shocks i need online - might have to go to part store and show a pic.
i have z56 RPO but i can't seem to find what i need
should be an easy replace there
yeah just rear, and standard PPV as far as i know - I'm real new to all thisThe rear, and standard PPV?
I have replaced mine with OEM shocks. They’re shorter than non PPV units. I can look at my logbook for the numbers when I get home.yeah just rear, and standard PPV as far as i know - I'm real new to all this
I *believe* the z56 here is the suspension if that helps
happy to get any information that might help you help me and appreciate the assist
that'd be so friggen amazing <3I have replaced mine with OEM shocks. They’re shorter than non PPV units. I can look at my logbook for the numbers when I get home.
awesome! my searching wasn't turning up much, sincere appreciation
