What did you do to your 21+ T1XX today?
nick14226
5 weeks ago was my first (in Buffalo, NY). Those rear lower control arms plow some snow!
66 Galaxie
66 Galaxie
Scratch that for the back up bulbs. After a trip to the store causing error code. May have to buy resistors now. Argh
zbad55
Army
Detroit
I forgot to mention that I also had the tint added to the driver and passenger side windows, I also had the smoke tint added to the bright orange side marker lamp,
66 Galaxie
Installed resistors for back up light bulbs. Fingers crossed that this takes care of the error message. ;-)
Looking at the wiring, I wonder if the taillights are the same circuits as the trailer light plug. If so a resistor harness could be made to just plug in to the large round trailer plug to create the additional circuit load to offset lower drawing LED inserted in our taillights.
Highly doubtful. The trailers light circuit on these new models has a sensor that tells the truck if a trailer is connected. There have been issues with trailer sensing. Trailer light circuits likely have separate fuses, like the older models.
Shrubs2K2
oHIo
First time in real snow and ice. 450 miles on Christmas Eve day to pick up my Aunt and bring here to our house. Used AWD most of the way as the roads were a complete mess.
Whitt
Looks like you might have GM installed power steps and mud flaps front and rear. If so, what brand are the mud flaps on each end? They appear to be effective.
Shrubs2K2
oHIo
The running boards are factory as it came with it. The mudflaps are weathertech Part Number: 110126-120125
Fast_AT4
RWM +1
SW Florida
4hrs later....Corsa installed. Wish they would make the pipes slip in a bit easier....but straight forward install. Videos to follow.
nick14226
I find having a d-ring on the back of my vehicles comes in handy and didn’t love the look without the hitch cover on the Tahoe. Started messing around with options and came up with this. Pretty happy with how it turned out. Maybe someday there will be an oem in-use option that will expose the trailer electrical connection and chain connection points that looks clean, but until then this should work for the d-ring at least.
ProfeZZor X
High Country
It's been raining for the last few days here in L.A., so I haven't had the opportunity to maintain my vehicle's usual cleanliness. But, what I do appreciate is that my wheel and tire setup performs exceptionally well under wet conditions. And that's under a 2-wheel drive & big brake scenario, not 4-wheel drive. The ride quality felt very solid, no hydroplaning, and I wasn't afraid to give it a little gas or hit corners with the same confidence I have during dry conditions... I'm definitely happy with this setup.
CASTLEDFW15
North TX
Called my mobile detailer and performed hand wash insidee and out. Also did my Charger. Got the clean up from the recent road trip.
shekmark
Senior Member
Jersey Shore
I find having a d-ring on the back of my vehicles comes in handy and didn’t love the look without the hitch cover on the Tahoe. Started messing around with options and came up with this. Pretty happy with how it turned out. Maybe someday there will be an oem in-use option that will expose the trailer electrical connection and chain connection points that looks clean, but until then this should work for the d-ring at least.View attachment 388334View attachment 388335
Is that an aftermarket hitch cover?
nick14226
OEM cover, used a dremel to cut it out and added a rectangular trim piece (actually meant for extending outlets I guess). To my surprise the color matched pretty close.
CrackerJack135
