Front End Rebuild
Guys, I have a 96 Tahoe 2door 4wd. It has 265000 miles on her and I would like to completely rebuild the front end/suspension components. Is there a build of materials list for this job or what are your suggestions for the different components?
Thanks
GMT800 2005 Tahoe Z71
Navy Supporting Member
Steering rag joint, inner and outer tie rods, all 4 shocks, frame and end bushings for front and rear sway bars, upper and lower control arms with bushings and ball joints, center link if worn, idler arm, pitman arm, check steering gear for loose at frame and any cracks in frame where gear mounts, check spring bushings....etc. Check power steering pump mounting and the pulley and belt. P/S hose leaks.
Check spring U-bolts and nuts.
The rear suspension needs to be as tight as the front for proper handling.
C
That’s a great list. Any specific manufacturers or vendors to go through for parts?
veteran111
