I appreciate your input. I'm def no mechanic myself. I looked at the fluid level again in the master cylinder yesterday and it does appear low now. Still no leaks on the ground or under the master cylinder.
Might only leak when the brakes are applied hard. Have your gf start it up and step on the brakes while you look at all 4 wheels as well as the MC and also the brake lines themselves. Hopefully you don’t have rusted lines.
Scottydoggs
NJ
I don't claim to be an ASE mechanic or brake expert. But, based on the facts that your pedal goes squish to the floor, has some pedal after a pump then squish to the floor...
If there is no fluid spraying onto the driveway, hoses are still attached/intact and fluid level is good, I would suspect vacuum booster is leaking by somewhere.
It is pretty much the only other thing between your foot and the brakes that might make the pedal do what it is doing.
This is my bet on what you have going on.
I certainly welcome all opinions from people who really are more qualified than I am.
no vacuum to the booster nets a rock hard pedal nothing more. would feel like if you pump the brakes engine off. the pedal gets rock hard in 3-4 pumps. even with hydro boost, engine off pump the pedal. rock hard. and this vac leak to the booster would also cause a lean code and lots of idle surging.
@Tonyrodz my line rusted out right above the rear end on the drivers side. I didn't see the leak until it was on the lift at the alignment shop the second time.
Thanks for the heads up on that. Mechanic replaced all those lines when the rear was swapped out, but I will check all connections.
MassHoe04
Western MA
Thank you for teaching me some new stuff here @Scottydoggs ... Anytime I can learn, is much appreciated!
MassHoe04
Western MA
Quick scan and go this morning...
This is why I keep my Zurich scanner in the center console.
So I don't even have to get out in the unusually heavy downpour, go inside to get the scanner, just to find out the CEL is only the P0442 code (one stored and on pending) I can ignore for now. Off to work I went, with no worries!
Looks like the Purge valve replacement took care of my "Tighten Gas Cap" messages and CEL codes for Large Evap Leaks, but looks like I'll be checking vent/canister/tubes when warm weather returns next spring...
Sam Harris
I had one of these last week.. d’oh..! I’ll be looking for a solution as well. If my damned back would get a tiny bit better, I would be able to do a lot more.
I feel your pain Sam. I was leaning over for a few hours fixing the Vic. My lower back is aching too. Getting old ain't for the weak brotha.
I checked the brake line connections in the rear. They're all dry and appear tight, so those are good. I see some wet spots on the driver's side front wheel well liner. Thought it was brake fluid--nope. It was grease from the cv axle, that I replaced less then a year ago.
I saw the rotor grooved a little too, just on the outside. Checked the mc fluid level and it actually looks lower. Wasn't able to check any further as it was getting dark.
albac
