Radio stays on, dome lights dont turn on.
JaxPizzaDad
Good morning. I have a 2012 Tahoe LTZ. The interior pull handles were trashed in both driver and passenger sides. I replaced both door panels with panels from a 2010 Avalanche. Window bezels were included and everything works as it should. However, now the truck doesn't recognize when the front doors open. When I torn off the truck the radio stays on and the lights dont go on. Obviously has to do with the panel replacement, but I would like to know how I can fox this issue. Thanks.
could be a a couple things either you left something unplugged or something is not plugged in correctly or if you also changed the door switches/window controls then it's possible those will need to be re-programmed to your vin. some features go thru the door switch so if the avalanche did not have those features it won't work on the LTZ until it's programmed.
J
JaxPizzaDad
Thanks for the feedback. How do I reprogram the window switches? Does thay have to be done by the dealer?
by a dealer or with a tech2 or similar 2-way programming tool, snap on, bosch, autel, etc, you will need to pay for the programming access if you do it yourself gm charges $40 for 2 years of programming per vehicle vin number
DJones
Largo, FL
I had the same issue. Somewhere along the lines of previous owners, my driver door switch was replaced. I used a VCX Nano and a subscription to ACDelco Techline Connect to program it. Ended up being relatively easy.
Hodmjstone
