Anybody stumble across good black chrome lug nuts? I went the aftermarket spline lugs when I switched to the Black Silverado wheels - of course they were painted black so the look like crap now! I prefer no chrome at all and want to stick to the storm trooper theme of white/black only.
just grab a set of key locked lug nuts in black chrome, like these
Fubar0715
Scott
Southern New Hampshire
Are splined nuts better than hex, besides the security benefit? Do they show less wear from install/removal?
I'm not sure I'd like having to keep track of the key, just seems like another potential problem.
I threw the spline key in the center console or glove box - I got 2 with my POS lug nuts. I feel like most of the aftermarket lugs are painted and I will end up with the same issues I have today.
i don't know if they are any better or not but the ones I have seen are black or black chrome, not painted
My new wheels should be coming early next week, then I will install the TPMS sensors and go and get new rubber put on them in the next couple weeks. I might wait and see what, if any, black Friday deals can be had for tires.
I need to but new lug nuts. What y'all think would look best with these black wheels with machined face? I was thinking black, because the area the nut is in is black so then it'd blend in and not be noticeable, but then I though chrome because I have a bit of chrome on the vehicle, just not on the wheels. Then what style, acorn, splined, hex, flat top (wife's Acadia 20" wheels came with chromed flat top lug nuts).
I vote black but I hate chrome anyway.
St. Louis
Wheels came early! Think I'm gonna go with black lug nuts, altho the center cap on these wheels look chrome.
New tpms sensors should be here Tuesday. Do you guys use any sealant around the base of the stems when installing?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I use a thin film of assembly lube or syl glyde when I install my valves. Helps them pop into place easier. Even dish soap will work.
^^^ This. Nothing like rim sealer, just a good lubricant that's compatible with the stem material. A little syl-glide or dish soap would be my choice.
I use Dawn to install valve stems or any other rubber parts, just need to help them pop into place.
St. Louis
Cool, so no sealant just lube.
I have this in my tool box and use it on O-rings, like on injectors. It's water based and doesn't mess with anything.
a couple years ago I did a failed attempt at epoxying the wood trim back on the steering wheel, it held for the most part but this summer it actually came completely loose but would "stay on" so last night I gorilla glued it, it appears to have worked well and as gorilla glue likes to do it expands even though I only used a tiny bit, I just used a little tool and cleaned up the seam. I have a brand new wheel to put on without wood trim but saving that for future use.
St. Louis
I hated my Denali wood wheel. It wasn't separating, but the wood wouldn't heat, just the leather side would, and the wood would stay cold, lol.
I changed that thing out within the first year I owned it. The non-wood wheel feels thicker and so much better and keeps my hands warm in the winter... Lol
Hodmjstone
