2017Tahoe 4x4 making weird low hum - front left
GMT800 2005 Tahoe Z71
Navy Supporting Member
Your interior controls may say the AWD is not engaged but maybe it is. Damn things lie like a dog, all the time.
TahoeFL2017
TahoeFL2017
Tow/haul I made sure was off by holding down the button for a full 10 second count
AWD is noticeably different when I turn on/off so that’s eliminated
Friend is a Service Manager and off tomorrow so he’s going to drive it hopefully he can figure it out based on his experience
Update tomorrow!
TahoeFL2017
TahoeFL2017
Friend drove it, thinks it's a tire, so off to Tire Kingdom to rotate/inspect under the tire warranty. Update later, might be a tire, or if not it's time for the dealer.
Still can't get the noise to change by swerving , so tire is most likely at the moment.
TahoeFL2017
TahoeFL2017
Update - tires rotated, noise is still there, maybe slightly better?
Thinking bearing or hub in the very beginning of failure, doesn't vibrate or pull, just a low humming noise, gets worse after driving 20 minutes or so.
Blackcar
Getting a weird low hum, not loud but annoying, seems to be from the Driver's side front wheel, nothing looks amiss though
No pulling or shaking, and the caliper doesn't appear to be dragging, so shouldn't alignment or brakes, truck just feels "heavy" , checked tire pressure, put in premium gas, etc
Recently put about 10k miles on newer tires, is this maybe a big nothing?
Tires breaking in weird maybe?
Feels like a slight drag, almost like the 4x4 is on, but not quite that much - just enough to be noticed
Any ideas?
Is this a 8speed automatic and what is mileage?
RST Dana
OH
I had a bad bearing on the rf of my 17 a few Mike’s ago. Probably around 50k on it. No pulls, only a slight roar when coasting.
TahoeFL2017
TahoeFL2017
Update - after hearing a rattle on startup over the weekend, I've concluded this is a exhaust issue, either a clamp rattling or something else that is loose.
Tires checked out, hub/bearings aren't looking like their the problem, and now that I think it's exhaust, it sounds more like it every day, and I'm going to get it checked out up on a lift.
I think I noticed it more as the weather cooled off, as I stopped having the AC on blast like all summer, so the cabin is quieter.
Appreciate all the replies, this forum is great, and if it's anything besides exhaust, I'll update.
Dh1280
